Old 08-05-2006, 09:23 AM   #1 (permalink)
tiblu's Avatar
Question What do u think of this MOBO ? ? ?
Hey guys is this Asus A8N SLI SE a new mobo is it good.
http://www.asus.com/products4.aspx?l...89&modelmenu=1
tiblu is offline
Old 08-05-2006, 09:33 AM   #2 (permalink)
Default Re: What do u think of this MOBO ? ? ?
In one word, YES. But unless you want an SLI rig, why waste money on this? Get a A8N-E instead.
drvarunmehta is offline
Old 08-05-2006, 09:46 AM   #3 (permalink)
tiblu's Avatar
OK d.mehta i think ur right, i have heard A8NE chipset fan problem hav they solved it.
tiblu is offline
Old 08-05-2006, 11:39 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
ASUS A8N-e chipset fan problem was there but in Revision 1.00 mobo. Revision 2.00 onward it has been solved. So when buying do check that u get a Rev.2 mobo. Just look for Rev. 2.00 printed on the mobo under the name(ASUS A8N-E).
As far as the mobo u mentioned, buy it if u have the money and want to have a SLI setup now or in future. Or simply stick to A8N-E or A8N-VM CSM.
By the way A8N-e is great for overclocking also.
john_the_ultimate is offline
Old 08-05-2006, 12:25 PM   #5 (permalink)
Manchester United
abhijit_reddevil's Avatar
I just want to remind you all of the fact that in all Asus mobos except A8N32-SLI deluxe, the SLI mode is X8/X8, i.e. when two Nvidia graphics cards are joined in SLI, they will operate at PCI-express frequency of X8, whereas the maximum is X16. Only A8N32-SLI deluxe has support for full SLI x16. Please keep this in mind when making a buying decision.
But A8N32-SLI deluxe is expensive (around Rs.19000), so I think if you are not so serious about SLI, get the A8N-E instead.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 10-05-2006, 09:42 PM   #6 (permalink)
samrulez's Avatar
Good....its SLI.....and its a revision over the old one
samrulez is offline
