Old 08-05-2006, 12:10 AM   #1 (permalink)
Default DVD Rom
My dvd rom si showing I/O error while i try to copy something from the cd to my hdd and one more thing my cd is in perfect conditions as i use my dvd writer to copy those cds to my hdd it works fine
can anyone help
freakabhishek is offline
Old 08-05-2006, 01:25 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: DVD Rom
Try to clean the lens and then try. What brand is it(DVD Drive)? Why are u using both DVD Rom and DVD Writer as any one would serve ur purpose (just curious)? More devices means more power requirement, right.
john_the_ultimate is offline
Old 08-05-2006, 01:57 AM   #3 (permalink)
Default Re: DVD Rom
I Have cleaned the lense still not working
its a sony
and by the way if i use more devices will it affect the speed of my comp
P4 2.8 Ghz
Asrock
512MB Kigston Pc 3200
Samsung 160 GB
LG DVD WRITER
Sony DVD ROM
Samsung 45Bn
Old 08-05-2006, 03:35 AM   #4 (permalink)
No pain....No gain
Default Re: DVD Rom
It is not about speed or performance but using more devices puts strain on ur SMPS. A good SMPS will take the load easily but a not so good one will cause problem.
By the way it was just my suggestion, don't panic. For ur config. a good 400W SMPS will do fine.
Regarding the drive, does it has problem reading that particular disk or all of them. If it's still under warranty then get it replaced or repaired by SONY.
