Can anyone tell me how to transfer data from one HDD to another.Or please suggest me any other option.Before that I want to say that I had no DVD writer and the purpose of all this is that I want to replace my old HDD.
if you want the working operating system to be also transfer, then use
"DriveImage XML"
is an easy to use and reliable program for imaging and backing up partitions and logical drives. --- it is freeware.
if you want just data to transfer, connect two harddisk and transfer data.
you never know what you can do until you try
thiz solution culd give some troubles sumtimes. go to first All Programs > Admidnistrative Tools > Computer Management > Storage > Disk Management > Click on the disk newly installed and IMPORT it.
