Old 07-05-2006, 02:27 PM   #1 (permalink)
ashfame's Avatar
Default Digi Cam
I wanna buy a digi cam but i don't know the things that i should look for.
Pl sugget some things to take care of.
It should have a memory card (about 1gb), i wanna take lots of shot with it.
About its battery, cables etc
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 07-05-2006, 02:39 PM   #2 (permalink)
Default Re: Digi Cam
hey !! u r a senior member here ....u must know what to look for in a digicam anyway look for optical zoom brand : sony nikon canon and must go to dpreview.com and Steve;s digicam .....they will satisfy all ur quaries about digicam
reddragon is offline
Old 07-05-2006, 06:00 PM   #3 (permalink)
ashfame's Avatar
Junior even i know things like optical zoom.
I just wanna know from a guy who himself has a digi cam else i can google it.
You need to grow up, boy.
BTW 1Megapixel camera can take a shot of what max. resolution.
My budget is around 8k.
It should have a LCD screen, memory card slot, good battery life & should be able to fetch video also.
ashfame is offline
Old 07-05-2006, 10:39 PM   #4 (permalink)
well I have 1 nikon coolpix p3 ...it satisfies my purpose ...in 8 k u can buy canon 410 from jjmehta and there r some other orite models available . my friend has canon 410 ....very good value for money..................
Old 07-05-2006, 10:42 PM   #5 (permalink)
gxsaurav
Posts: n/a
canon a400, best for your needs
Old 08-05-2006, 01:20 AM   #6 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Canon A410 would suit ur budget perfectly. Read the review here http://www.dcresource.com/reviews/ca...ew/index.shtml
john_the_ultimate is offline
