Old 07-05-2006, 01:30 AM   #1 (permalink)
bang bang!
Chirag's Avatar
Default My DVD Writer died
Today i took out my data cable to play pop:t2t. The game didn't work and hell after that my writer is not working. It is not even opening. No light is seen. What u guys think. What could be the prob?
Also suggest me the best best best available Dvd writer in market.
Chirag is online now
Old 07-05-2006, 01:39 AM   #2 (permalink)
Default Re: My DVD Writer died
Sony DVD writers are the best.. Go with sony..
I have been using it from the past 1 year.. i burn 2 to 3 dvds a day.. not even a single minor problem..
Top 10
Toocool is offline
Old 07-05-2006, 03:46 AM   #3 (permalink)
144
144's Avatar
I believe you've tried DAEMON tools to play Prince of Persia - and you unplugged your optical drives to fix some problems? did you?
Did you also trun of the Power - From the power source, plug point before doing so? Did you after that check if you had loosened any connection to the DVD RW drive? Check its power connection - Is it firmly fixed into position?
Check the IDE cable if its loose?
You say the bulb is lighting up - If you find all the proper power connections fixed and u still dont get any sign of life --- Run for your local hardware vendor -
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 07-05-2006, 04:20 PM   #4 (permalink)
lavan_joy's Avatar
1.I think you removed the cable without shutting down the PC. It might damage the DVD writer.
2.Sometimes the power cable also have problems.Try with anyother power cable with the dvd writer.
3.If you still have problems then go for SONY DVD writer or LG.
DON'T BUY SAMSUNG & BENQ
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 07-05-2006, 06:41 PM   #5 (permalink)
bang bang!
Chirag's Avatar
Yes I took out my power cable while my pc was on. I don't know what happened to me i took it out with running pc. Hell. I don't know where was my mind was. After taking it out i jst realised it. can it be repaired by myself? If yes than how? Also tell me some good models in sony and Lite-on.
Old 12-05-2006, 09:04 PM   #6 (permalink)
varkey's Avatar
i have not had any probs till now by removing or connecting dvd drives etc while the machine was on. try using a idfferent power cable.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 12-05-2006, 09:37 PM   #7 (permalink)
shouldnt be a major prob. while removing power cable while the system was on, try changing the power or may be even the ide cable..check if dvd is working at other place
cyrux is offline
Old 13-05-2006, 12:11 AM   #8 (permalink)
bang bang!
Chirag's Avatar
I gave the writer to my vendor and he said it can't be repaired. I asked what is the reason? He said I don't know. I asked than how can u say that it can't be repaired. He said - The guy who checked said that it is a major prob. THan what is the prob? He said - I don't know. Hell I came out of there with my writer.
So guys plz tell me what can i do? Any more suggestions except changing the wires. I think the prob is with power cable or that power cable connector. Cable can be changed but can teh connector be changed?
Old 13-05-2006, 07:25 AM   #9 (permalink)
jay4u's Avatar
go for either sony 810DRU or OEM or liteon DVD RW
Passwords are like underwear... Change them often...
jay4u is offline
Old 13-05-2006, 07:32 AM   #10 (permalink)
jay4u's Avatar
jay4u is offline
Old 14-05-2006, 02:36 AM   #11 (permalink)
samrulez's Avatar
Just check again if the power connector is working..Disconnect it from the writter and connect it to a fan,,,,if the fan works then u r DvD writter has gone to Hell ...........Go for a Liton DvD writter
samrulez is offline
Old 15-05-2006, 05:42 AM   #12 (permalink)
just enable the the device again as u might have use star f#ck tool to play the game rt click on any drive(c,d,e..) ---------> Hardware select u r dvd writer [/b] ---> properties u see general...at bottomselect enable the device thats it .
try this
hermit is offline
Old 15-07-2006, 10:54 PM   #13 (permalink)
Do the following
1) Replace your IDE Cable
2) Format your computer and install Fresh Windows
3) Go to bios menu and see whether DVD+RW is detecting
Prince Stephen Ranji is offline
Old 15-07-2006, 11:26 PM   #14 (permalink)
Indian by heart
planetcall's Avatar
Its Simple. Your vendor has nothing to do with the DVD Drive. Ask him to forward the drive to yr drive's service center else you might ask the address and go to the service center directly. If you have yr warranty alive, it would be a boon and you might claim a free refund/repair.
planetcall is offline
Old 16-07-2006, 04:48 PM   #15 (permalink)
Well.....go for LG DVD Writers ..........
Navneel21 is offline
Old 16-07-2006, 08:16 PM   #16 (permalink)
Indian by heart
planetcall's Avatar
I own LG GSA H10A . Its truly one of the best drive available. Thanks I didnt listen to a few of the suggestions and decided myself to look around in the international forums for more expert views and comments. LG does provide one of the best Optical Drives.
Old 17-07-2006, 12:54 AM   #17 (permalink)
yogi7272's Avatar
benq dw 1650 is the best drive available .. .. if u want lots of features and quality dvd writing .. other wise lite on and lg will also do .. avoid sony .. just lite on and benq clone ..
i have benq dw 1640 , lite on shm 165p6s and lg h10 n .. features wise benq is best .. quality wise too .. its just that cheap dvd - r has problems with my benq .. but no probs with +r media .. anyways dvd writing is about quality than speed ..
yogi7272 is offline
Old 17-07-2006, 10:57 AM   #18 (permalink)
royal's Avatar
What is the brand of blank DVD-r that you have been using ?
And has anybody used "fake" MOSERBAER blank DVD-R that have the name written in silver instead of the usual red/black ? Are they reliable ?
royal is offline
Old 17-07-2006, 03:32 PM   #19 (permalink)
yogi7272's Avatar
I have benq 1640 .. not 1650 .. but both are identical in terms of hardware inside .. both based on excellent nexperia chipset of philips .. the cheap dvd -r brands i used were princo , datamax and some others i dont remember .. no probs with quality dvd -r media like moser baer .. and no probs with any dvd +r media .. i am using a media called unique which is like 10 rs each .. works well with benq and is pretty good too ..
yogi7272 is offline
Old 17-07-2006, 03:43 PM   #20 (permalink)
Wise Old Crow
blueshift's Avatar
My DVD Writer died
Sorry to hear about that!
http://twitter.com/blueshift155
blueshift is offline
Old 17-07-2006, 04:24 PM   #21 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Umm.. no.. 1640 and 1650 are diff drives with different hardware. Some Dual Layer writing issues were fixed in the 1650. In that regard, 1650 and 1655 are absolutely same. Just that 1655 has extra lightscribe hardware. Both can be cross-flashed to one another. Of course that does not mean you will get lightscribe if u flash 1650 to 1655, and you will loose lightscribe facility if u flash 1655 to 1650.
kalpik is online now
Old 17-07-2006, 08:07 PM   #22 (permalink)
yogi7272's Avatar
nope .. both are based on the same philips nexperia chipset .. only some parts as puh are different .. check cdfreaks .. few issuses with 1640 were solved with 1650 such as huge pif spike in the end of the disk when writing at 16x .. speed wise both are same ..
yogi7272 is offline
Old 18-07-2006, 08:11 AM   #23 (permalink)
kalpik's Avatar
Yes of course! Both are based on the phillips nexperia chipset, but the chipsets are different! Its like saying FX5200 and 6600 have same hardware cuz they are based on the Nvidia chipset. If they are ctually same, then you should be able to cross flash between 1640 and 1650, which is not possible.
