Old 06-05-2006, 09:05 PM   #1 (permalink)
Default System not starting
I m getting problem with my CPU. It is not responding anymore. When I start my system, motherboard activities are OK but nothing is displayed on the monitor. even the POST and BOOTING is not there. I've tried to change the monitor, but the same problem persists.
plz show me the way..
ganesh_dabhade is offline
Old 06-05-2006, 09:33 PM   #2 (permalink)
Default Re: System not starting
Did u check the cable connections,or possibly if the monitor is switched on.
does it have any CPU activity indicated by the LED display
Did u also check for loose cable connection.
Ace Ventura is offline
Old 06-05-2006, 09:46 PM   #3 (permalink)
phatratt's Avatar
1)Check u'r ram sticks,
2)reset u'r bios setting to default by removing the battery
3)Check SMPS performing well
4)make sure all cables are fixed properly
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 06-05-2006, 11:03 PM   #4 (permalink)
Do fans in cpu start,is there any beep after some time?
Mayur is offline
Old 09-05-2006, 10:20 AM   #5 (permalink)
RAM is OK,
SMPS is OK, Power cables r also OK
I'd reset the bios. nothing works. i've also replced the monitor, other monitor also responds the same as previous.
CPU activity: orange and green lights always on
Old 09-05-2006, 10:42 AM   #6 (permalink)
abracadabra's Avatar
Do u get any beep sounds ????? like a continous one or eight conecutive beeps ???
abracadabra is offline
Old 09-05-2006, 05:44 PM   #7 (permalink)
And if the beeps are not there then just open the cabinet, remove the fan and check the proccy too (physically)!!!!
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
