Re: Hard Disk Partition Scheme
I typically make four partitions on my HD - one for system files (Windows), one for Programs, one for Data and one for backup... With a bigger HD at home, I also have one separate for Games and one for installation files... Here, depending on your needs you should partition your drive. Since I dont know what kind of files you store (music, movies, work data, etc), I cant give you a good reply... However, as others say, in most cases 10 GB is not enough... 80 GB is the norm today and very soon, this will shift to 160 GB...
Also note that you said you want to play games like Kotor2... If each game is about 4 GB size, how many games can you install at a time?
Arun
