Re: Another Upgrade query!
An upgrade of 512MB of RAM is not adequate in my opinion. I would suggest atleast an 1GB RAM upgrade. Forget the HDD. In your case, upgrading to add another PATA HDD is not solution, as I would suggest. My reson being that, such multimedia exp. (if not for space req.) does not requre u to increase ur HDD size.
If you have a seperate partition (Other than your Windows Partition), install Photoshop on it.
Don't make your Windows Partition your PS Scratch Disk. You can remedy that in preferences> Scratch Disks of Photoshop. Better if you make a seperate partition just for scratchs (Some recommend that, yet I have not experienced a speed boost with it).
RAM is the Ultimate factor.
It is a different matter if you are going to upgrade to another HDD type with faster access speeds than your already existing PATA drive.
And I would suggest you get a low end, but decent AGP Card. nVidia 6600 is excellent at a low budget.
Make sure you buy RAM of the same ?Clock speeds - I don't think you'd have any issue then, but I'd leave that recommendation to someone with more exp. in RAM Modules and its compatability.
On a long enough timeline, the survival rate for everyone drops to zero
