Old 04-05-2006, 04:11 PM   #1 (permalink)
Default intel 2.8 and intel 2.8 HT
Hi
can anyone tell me the difference(Speed , price) between 2.8 and 2.8 ht processors
freakabhishek is offline
Old 04-05-2006, 04:35 PM   #2 (permalink)
Your Maker.
MysticHalo's Avatar
Default Re: intel 2.8 and intel 2.8 HT
HT=HyperThreading, a technique introduced by intel to make a single core processor handle multiple task, ie. behave like a dual-core proc.
But sadly this didnt give expected results, so it just remains....
I dont think non-HT processors r easily available these days, moreover why not take HT if its available. Price=> NON HT= Rs 6k; HT= somewhere arnd 8k
Plus, 2.8 GHz is low for an intel pro. ....should be over 3 GHZ to have some life(i know conroe is gonna kill this anyway)
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 05-05-2006, 06:37 PM   #3 (permalink)
digiFriend's Avatar
Lightbulb Re: intel 2.8 and intel 2.8 HT
intel is all about HYPE, if you want performance, select AMD
you never know what you can do until you try
digiFriend is offline
Old 06-05-2006, 06:02 AM   #4 (permalink)
144
144's Avatar
HT does give a performance boost in my case. I do renderings in 3DS Max -
The CPU acting as to logical units does decrease the time taken 2x. Really helpful. I am unable to achieve such performances even on an AMD...Sometimes its better to have an Intel. Right?
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 06-05-2006, 08:43 AM   #5 (permalink)
BE FREE
Originally Posted by freakabhishek
Hi
go for 3.0 EM64T, as it will support 64bit computing also.
azaad_shri75 is offline
Old 06-05-2006, 11:33 AM   #6 (permalink)
Arrow Re: intel 2.8 and intel 2.8 HT
my 2.8 also support 64bit computing as it is EM64T
Old 06-05-2006, 02:11 PM   #7 (permalink)
144
144's Avatar
Do you actually get any benefit with a 64-bit OS? Mine doesn't give me any?
144 is offline
Old 06-05-2006, 03:37 PM   #8 (permalink)
In my case also I saw a performance boost with the HT enabled P4. But in my case I have a high end Mother Board with DDR-II.
But the processor stays very hot all the time. Mostly above 60 Deg C.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 08-05-2006, 12:50 PM   #9 (permalink)
The Researcher
I would suggest to go for HT processors, esp, 3.00 Ghz with 2MB cache as most of the furture applications may require this kind of processor power.
Ramakrishnan is offline
Old 08-05-2006, 03:26 PM   #10 (permalink)
 Macboy
goobimama's Avatar
It depends on what applications you are using. Photoshop for example is coded to handle dual-processors, dual-core processors and in this case, the HT...
I'm like a bird... :)
goobimama is offline
