Old 02-05-2006, 08:05 PM   #1 (permalink)
Default Ram Help
Can anyone tell me if i use a 512 Mb kingston ram with clock speed 400 on a asrock motherboard which supports speed upto 333 , decreases the speed or not
and by default the motherboard shows it as 266 but after changing the settings in the bios it shows 333
My processor is 2.8 HT
freakabhishek is offline
Old 02-05-2006, 08:19 PM   #2 (permalink)
ashfame's Avatar
Default Re: Ram Help
your new ram will run @ 333mhz
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 02-05-2006, 09:58 PM   #3 (permalink)
Will it effect the speed of the computer
Old 02-05-2006, 10:01 PM   #4 (permalink)
dIgItaL_BrAt's Avatar
it won't affect the speed of the computer.
The RAM will just underclock itself and run at 333 Mhz.
dIgItaL_BrAt is offline
Old 02-05-2006, 10:48 PM   #5 (permalink)
Thanks for the assistence
and such prompt reply
Old 02-05-2006, 11:33 PM   #6 (permalink)
No problem,dude.
Always here to help.
