Old 02-05-2006, 01:46 AM   #1 (permalink)
Default IS it OVERHEATING???
I hav intel p4 3.0 ghz processor with HT.
i hav 2 Hard disks, 1 SATA of 160 GB and 1 PATA of 80 GB.
ram is 512 MB
my comp starts wid a temp of 40C but in about 40 mins it goes upto 52C. it becomes stable after reaching 56C.
Is my cpu overheating N how can i Prevent it....wat's da ideal temp...
ashishkhetriwal is offline
Old 02-05-2006, 01:56 AM   #2 (permalink)
Ishan's Avatar
Default Re: IS it OVERHEATING???
u can search in previous posts for this topic.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 02-05-2006, 10:51 AM   #3 (permalink)
No it is not overheating.....Prescott are meant to run hot......their temperature can go up to 75 to 80 when it starts to throttle....and if u want u can add a 120mm fan exhaust and 80mm intake which i am doing it idles at around 48 to 52
zuala77 is offline
Old 02-05-2006, 10:51 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
I think the temps are fine. The pentium 4's does run at high temps, especially the PRESCOTT. The threshold is 70-75C, correct me if I am wrong.
Also see this http://www.digit-life.com/articles2/...ing/index.html
john_the_ultimate is offline
Old 02-05-2006, 10:54 AM   #5 (permalink)
bang bang!
Chirag's Avatar
Hey When i open speed fan . In tthat it shows that my one fan is not working i.e it is 0rpm. IN Bios when i enable CHA1 warning. It says that it is not detected. What shld i do?
Chirag is online now
