Old 02-05-2006, 01:33 AM   #1 (permalink)
Angry System Restarting
I Have P4, 2.0 Ghz,256mbram,40gbhdd.gigabyte 845motherboard.i Have Win 98 N Win 2000 Pro Installed.win 98 Works Good.but When I Log On To Win 200 Pro It Gets Restarted Always.
Pepsi™ is offline
Old 05-05-2006, 12:37 AM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: System Restarting
Might be some prob in MBR try repair WIN2000 with it's disk it will help to recover u frm ur prob
47shailesh is offline
Old 06-05-2006, 07:39 PM   #3 (permalink)
digiFriend's Avatar
also perform "scan" of the partiton on which win2000 is installed from win98
you never know what you can do until you try
digiFriend is offline
