Old 02-05-2006, 01:22 AM   #1 (permalink)
Angry Cd-rom Problem
My Cd-rom Tray Open Automatically N Closes Every Minute
Pepsi™ is offline
Old 02-05-2006, 10:37 AM   #2 (permalink)
Ishan's Avatar
Default Re: Cd-rom Problem
Wow! amazing prob.
but does that happen if there is a CD inside?
if not and if prob. cant be solved by anyone then try keeping the power cable of Cd drive out, and insert it whenever necessary!
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 02-05-2006, 01:05 PM   #3 (permalink)
Exclamation Re: Cd-rom Problem
Strange!!!
May be button of ur cdrom is pressed continously or if u use multimedia keyboard the eject buttin may be pressed continously,
Try checking ur Cdrom in some other sysstem, if same prblm occurs then time to get the new one.
Andyiz is offline
Old 02-05-2006, 03:34 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
@Ishan
What a silly Solution! How can you connect the cable whenever you need to run some CD-ROM and then remove i when you dont need it? Aint that some risky business?
As for Pepsi's problem, the CD-ROM happens to have a pressed button. Did you bang your drive or jerk it before the problem erupted? If so, get your drive serviced. If this doesnt help, get a new drive; preferably a Combo or DVD Writer.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 02-05-2006, 04:25 PM   #5 (permalink)
hey its not either power problem or button problem its bcoz of a virus check your system for virus this should solve your problem ....................
balu_c is offline
