Originally Posted by balu_c
hmm, everybody says u can install 3 os but real deal is what file system your harddisk is on. if your hard disk is partitoned as NTFS, u cant have multiple boot option u can hav only that os which is on primary partition.
Says WHO ???????
This is the first time I heard such a statement !
I might be wrong but whatever little knowledge I have, I'll try and explain this.
U can install multiple OS on a single drive provided u have enough space and u partition the drive properly.
For ur requirements, u have to have at least 3 partitions on your hard drive for each OS.
Then U have to format the C: drive as FAT32 so that u can install Win98.
Install Win98 on that drive.
After u install Win98, u have to install Windows 2000 on the 2nd partition and then WindowsXp on the 3rd.
I mean to say that, u have to install win98 on C: and then u can install the Windows2000 and XP on any of the other partitions (don't install them on the same partition please)
I would recommend u to format the win2000 and XP partitions as NTFS for better performance and security.
But u won't be able to access the NTFS drives from Win98 directly. U have to use some tools that u will get on the net for that purpose !
I explained whatever I thought would be enough for u !
I hope I kept it simple....
If u still have problems.....I give this place a visit every other day !
Feel free to ask here or PM me !
