Old 29-04-2006, 09:36 PM   #1 (permalink)
Default Mobo + Processor
Guys
i wanna upgrade my computer by changing these under 15k . so please suggest me .
1 . motherboard ( intel / amd)
2. processor (intel / amd)
3. monitor 17 "
Dont die of ignorance .
digitizen is offline
Old 29-04-2006, 09:40 PM   #2 (permalink)
ashfame's Avatar
Default Re: Mobo + Processor
Pl wait for other senior members to reply, till then visit this link:
http://www.techtree.com/techtree/jsp..._id=556&page=1
Choose the things you wanted, just a little above 15k.
Make sure you go for a mobo that will satisfy your needs in the coming years.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
