i hv a LG dvd-rom drive sometimes its working properly. But sometimes i does no ejects no matter whatever i try so at the end i hv to use a pin to eject it
when a cd is kept in it then there is no problem with the drive ejecting out.
so plz tell me what the problem is?
is the problem related to lens assembly?
i m waiting 4 ur reply
this is most common problem ,and thats why pin hole eject is given.(you can call it as aging problem).problem is with locking tray assembely of cd/dvd rom . if this mechinal lock does not work properly,then result is what you are getting -STRIKE
you never know what you can do until you try
its nothing to do wit DVD lens Its d problem of grear assembly or what is so called lock in drives u can't do anything about it.if u know how 2 resolve do by urself or go to a nearby vendor.
