Old 28-04-2006, 02:08 PM   #1 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Question Colourblind Monitor
Hello All,
I have a problem with my Vintron 15' monitor. I was playing a Game on my PC, when, suddenly the Screen got a Bluish tint. After some inspections, I saw that Red colour was not being shown at all. Hence, no Red and the colours with the combination of red look stupid.
I suspect either the CRT has some fault, or the Cable has some fault.
Is there any tweaks that I can do to to restore the colour??
Thanks for any help.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 28-04-2006, 05:34 PM   #2 (permalink)
adit_sen's Avatar
Default Re: Colourblind Monitor
this had happened to my Compaq 17" monitor sometime back. I got it checked up and found that apparantly one of the transistors had gotten burned due to excess current flow. So it costs me about Rs.650 to get it fixed.
So i'd suggest u'd get it checked up...
peace...
aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 28-04-2006, 06:48 PM   #3 (permalink)
Ethan_Hunt's Avatar
It seems like the cable wire have got messed up.Possibly might be a problem of loose connection.Have a hardware guy check it out and make necessary adjustments.
V for Vendetta
Ethan_Hunt is offline
Old 28-04-2006, 07:15 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Most probabily some h/w problem as adit_sen suggested!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
