Old 27-04-2006, 11:13 PM   #1 (permalink)
ashfame's Avatar
Question SMPS fan
my comp cabinet heat up a lot after being on for a few hrs.
i think my smps fan is not working properly.
i hav one more fan on the side of cabinet which i am sure is working good.
from speedfan 4.28, it shows two fans one @ 29rpm & other @ 0rpm.
whats the problem??
my hdd is @ 47'C, whats the ok level of temp of hdd 7200rpm?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 28-04-2006, 05:33 PM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: SMPS fan
whats the problem??
dont worry about speedfan....
clearly u have a poor air flow...
do u have fans at the fromt of ur case....
47c is a bit too high... although it will not kill ur HDD but is not a good temp....
42-43c is fine......
Kniwor is offline
Old 28-04-2006, 10:03 PM   #3 (permalink)
ashfame's Avatar
No i only have one fan on the side of cabinet other than the smps fan.
what should i do?
Suggest me a remedy..
ashfame is offline
Old 29-04-2006, 02:43 AM   #4 (permalink)
Learner
Kniwor's Avatar
ok,
take a 2 sided adhesive tape..... now purchase one of those Rs. 50/- fans....
cut about 1 sq. inch adhesive tape and stick it to the middle of the fan..... and now stick the fan on the top of the HDD....... now the fan will blow air on the HDD and the temperature will decrease to 40c we hope....
this is a great thing to do and in all the systems that i have no fans on the front... i take care of my HDD in this manner...... and this works great.... and perfectly silent....
in my main system... i have the HDD just in front of the 2 front fans..... this is the place where all the air in my system enters..... so my HDD is as good as kept out of the case with a fan on it....
it remains very cool....
Kniwor is offline
Old 29-04-2006, 12:07 PM   #5 (permalink)
ashfame's Avatar
ok,
I have an additional fan similar to the one connected on side.
How to connect it to motherboard, what type of plug does i should search for.
A picture of the connector would be appreciated.
Thanks in advance
ashfame is offline
Old 29-04-2006, 04:39 PM   #6 (permalink)
Learner
Kniwor's Avatar
u should have fan connections on ut motherboard.... similar to the one where ur cpu fan gets connected.... if not... u get fans in market... that i was talking about... for rs. 50/- that connect to the psu... and that is what we get all around here in india.....
Kniwor is offline
Old 01-05-2006, 10:37 AM   #7 (permalink)
ashfame's Avatar
I will be patching a fan for hdd in a day or two but What should i do about the smps fan?
ashfame is offline
Old 01-05-2006, 10:42 AM   #8 (permalink)
Learner
Kniwor's Avatar
is it not running at all ????
how many fans do ur smps have
Kniwor is offline
Old 01-05-2006, 11:45 AM   #9 (permalink)
ashfame's Avatar
i suppose it has only one.
its running but slower than the one on the side of cabinet.
Do ya know any utility that shows all physical reports (temp. of everything etc).
ashfame is offline
Old 01-05-2006, 10:32 PM   #10 (permalink)
Learner
Kniwor's Avatar
u cannot get temperature reports if there aer no sensors.....
Everest will report u about cpu, gfx card, HDD, chpset etc...
i u want more details u have to add sensors.... which i dont think are cheap
Kniwor is offline
Old 02-05-2006, 01:48 AM   #11 (permalink)
Ishan's Avatar
i was having the same problem as ashfame, and was having same no. of fans in my PC at the same places as he,....But i did nothing as i thought it would be OK.( a bit lazi).
finally in 2-3 days smps gone, some noise started coming from it, and we had to replace it. now everything is OK.
so whatever u want to as soon as possible.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 02-05-2006, 08:49 AM   #12 (permalink)
ashfame's Avatar
Is Everest freeware .....?
If not is there any freebie for this.
ashfame is offline
Old 02-05-2006, 11:28 AM   #13 (permalink)
Learner
Kniwor's Avatar
speedfan
and everest home edition is freeware
it is removed from their site but u can find version 2.2 around...
look popular download sites...
majorgeeks, download.com etc...
Kniwor is offline
