Old 26-04-2006, 10:27 AM   #1 (permalink)
sychomayniac's Avatar
Default To buy or not to buy
Hi i wanna know is nvidia 6100 mobo is nforce 4 chipset mobo. Is MSI NEO 4 platium board good or ASUS A8NE a worth upgrade both Nvidia 4 Ultra mobo great OCer. I m using 3200+ veince 512 twinmos, hitachi 80 sata II.
sychomayniac is offline
Old 26-04-2006, 11:04 AM   #2 (permalink)
Manchester United
abhijit_reddevil's Avatar
Hi, you can use Asus A8N-E. The only thing that will be missing there is IEEE 1394 and SLI support. And yes, it is a great overclocker. Overclocked mine to 2.43Ghz on stock cooling and stable as a rock.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 26-04-2006, 12:24 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
See if u want an mobo which has both option (onboard video controller and PCI-E 16x gfx) then I would suggest u to go for ASUS A8N-VM CSM having NVIDIA 6150 onboard gfx.
If u want a good performing mobo without onboard gfx and non-SLI then buy ASUS A8N-E. I am using it for more then 6 months and is a great overclocker. Overclocked mine AMD64 3000+ venice (1.8GHz) to 2.7GHz with stock cooling and stable.
If u want an SLI mobo then go for ASUS A8N-SLI PREMIUM.
john_the_ultimate is offline
Old 26-04-2006, 02:27 PM   #4 (permalink)
Learner
Kniwor's Avatar
nForce 4, nVidia 6100, nVidia 6150, and nForce 4 Ultra
there are for diffrent chipsets not to be confused....
if u need one with integrated graphics...
ASUS A8N-VM, nVidia 6150 is a good choice...
MSI K8NGM2 is equally good
if u got a PCI-E graphics card
ASUS A8N-E based on nVidia nforce 4 Ultra is a great mobo with very good overclocking features... go for it...
Kniwor is offline
