Old 16-04-2006, 07:29 PM   #1 (permalink)
samrulez's Avatar
Default Direct X Does Not install????????
I have an AMD Athlon64 2800+ (754) ON AN MSI K8M Neo-V based on VIA K8m800 Chipset.It has onboars Via UniChromell Pro IGP.
The Prob is that Direct X does not install, even after installing it shows 4.09.0000.0904.Is it because the IGP is not Direct X Compatible.And no games detect Direct X. Pls Help me out!
samrulez is offline
Old 16-04-2006, 11:04 PM   #2 (permalink)
mayanksharma's Avatar
hmm..
You can try again by reformatting your pc.
mayanksharma is offline
Old 16-04-2006, 11:08 PM   #3 (permalink)
samrulez's Avatar
Mayank,
I tried formatting my pc but the problem persists.Is the 4.09.0000.0904 the latest one 9c Can u check in ur pc
samrulez is offline
Old 16-04-2006, 11:29 PM   #4 (permalink)
4.09.0000.0904 is indeed DirectX 9.0c. I ran dxdiag and it said my version was DirectX 9.0c (4.09.0000.0904). If you haven't done so already, Go to Start>Run and type dxdiag and hit Enter. The window that pops up will tell you what DirectX version you have.
@mayanksharma: Formatting should be the last option. Please don't go around telling people to reformat just because you didn't know what else to do. All it needed was a dxdiag text which makes it clear that 4.09.0000.0904 is indeed DX9c.
Nemesis is offline
