Old 16-04-2006, 12:38 PM   #1 (permalink)
Default processor speed problem.....
i hav AMD Athlon Xp 2400+
the processor speed shown is 2.01Ghz
&&& my frnd has same processor but speed shown is 1.57GHz
why ??? whats the problem??
(NOTE: i hav not overclocked my machine )
pushkar1986 is offline
Old 16-04-2006, 12:42 PM   #2 (permalink)
samrulez's Avatar
Default Reply
Well it is because Athlon XP 2400 has 2 models both of them are based on different cores and different speeds
samrulez is offline
Old 16-04-2006, 02:14 PM   #3 (permalink)
Learner
Kniwor's Avatar
will u tell both ur cpu-z reports
Kniwor is offline
Old 17-04-2006, 12:45 AM   #4 (permalink)
samrulez's Avatar
Check wheather both the processors are running at the same FSB/core voltage
samrulez is offline
Old 17-04-2006, 02:54 AM   #5 (permalink)
his is not ATHLON his must be sempron
or
remove jumper j1 on mobo ,which is used for ram for 200mhz
hermit is offline
