Old 16-04-2006, 12:29 PM   #1 (permalink)
Default DVD DRIVE HELP!
My dvd writer can read and write cds but cannot even read dvds. I have the region set as 5.
I have a philips dvd+rw d28 drive...just set it up. I'm running windows xp, 512 ram,i have nero installed.
I installed latest firmware. another version of the firmware i was trying to install but i got an error - ASPI manager not found. On net i found different variations of the wnaspi32.dll file(ASPI manager file), one is 49kb,other 200kb and another inside nero folder is 168kb.
Is it a software/driver problem??
Please help me,
thanks
chillnow is offline
Old 01-06-2006, 12:21 PM   #2 (permalink)
Thumbs up Re: DVD DRIVE HELP!
Which OS u r using.....
I will explain for both
as for windows 98
The four files needed for Win95/98/Me are the following:
WINDOWS\SYSTEM\IOSUBSYS\APIX.VXD
WINDOWS\SYSTEM\WINASPI.DLL
WINDOWS\SYSTEM\WNASPI32.DLL
and ONE of the following two files
WIN95\SYSTEM\ASPIENUM.VXD (if u r using Adaptec drivers)
WIN95\ASPI2HLP.SYS (if u r using default Win95 drivers)
The four files needed for WinNT/2K/XP are the following:
WINNT\SYSTEM\WINASPI.DLL
WINNT\SYSTEM\WOWPOST.EXE
WINNT\SYSTEM32\WNASPI32.DLL
WINNT\SYSTEM32\DRIVERS\ASPI32.SYS
Download and auto ASPI Drivers
http://download.adaptec.com/software.../aspi_v472.exe (ADAPTECH ASPI)
http://ww2.nero.com/nero6/eng/ASPI_Driver.html (NERO ASPI)
reboot and check if it works
Sharing Knowledge Expands Horizon... And Problems r solved
bikram_singhy is offline
