Old 15-04-2006, 04:07 PM   #1 (permalink)
Default Please help me-an AMD rig.
Guys,
I'll be building a new rig for basically gaming and softwarez like Autocad, IDEA, CATIA, PRO_E etc.
I've shortlisted the items, since its an upgrade.
Please suggest the price of the following(Nehru Place, New Delhi, if Possible):
1. AMD 939 64 3200+/3500+
2. A good nvidia6150 + n430 chipset mobo.
3. 1 GB DDR 400 Transcend
4. Ati Radeon 1600XT
5. Seagate 160 GB SATA II
6. Zebronics Antibotic Cabinet
7. PSU-450W(Powersafe)
Also, Please suggest a good price for my old rig:
P4 Prescott 2.4Ghz
Intel 865 GBF
512 MB DDR Hynix
Samsung 80 GB SATA
Ati Radeon 9600
Creative Live! 5.1 DE
Samsung DVD16x
Samsung CD Writer 52-32-52
ATX Cab with 350W SMPS + 3 fans total.
gannu_rox is offline
Old 15-04-2006, 05:05 PM   #2 (permalink)
gxsaurav
Posts: n/a
All those softwares require good openGL capability, specially OpenGL 2.0 (IDEA)
Athlon64 3200+ is good enough for CAD, simply overclock it to 3500+ speed
Memory & rest is good
since u have a Radeon 9600 already stick to it, don't buy any other graphics card, that is enough for your needs, in case u wanna buy anyway, Better go for a 6600GT PCIe or if possible a 7600GT PCIe, from NVIDIA
Old 15-04-2006, 07:39 PM   #3 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Wen u investing in an graphix card y do u need a mobo wid onboard graphix.
i wud suggest going for ASUS A8N-E
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 15-04-2006, 09:37 PM   #4 (permalink)
ambrewz's Avatar
Default ur config is good
Ur AMD config sounds GOOD enough for all the things u want to do just a personal Opnion cause I don't use ATI I would recommend Nvidia 6800 GTX or 7800 if the Budget permits
:Techno::Qdalz:
ambrewz is offline
Old 16-04-2006, 11:47 AM   #5 (permalink)
Resident Weapons Expert
zombie's Avatar
I second that. Better opt for Nvidia. Because in this category it takes away the prize from ATi. But if we were talking about X1900 from ATi, then Nvidia doesnt even come close.
Stalk, Strike, Survive.
zombie is offline
Old 16-04-2006, 02:11 PM   #6 (permalink)
Learner
Kniwor's Avatar
there is absolutely nothing wrong in getting a 1600XT
it is a very good card.
usually ATI cards will perform better for that money... but lack in som imp features....
so itś a personal choice.....
Kniwor is offline
Old 16-04-2006, 10:42 PM   #7 (permalink)
jay4u's Avatar
go for asus a8n-e rather than asus a8n-vm.... its worth it....
Passwords are like underwear... Change them often...
jay4u is offline
Old 16-04-2006, 11:37 PM   #8 (permalink)
samrulez's Avatar
u can go for nVidia 7800GTX in SLI. if u can afford it
samrulez is offline
Old 17-04-2006, 12:46 AM   #9 (permalink)
maheswar2006's Avatar
Transcend, ok but also take a look at the CORSAIR valueselect. TOO good.\
Dont buy a single stick of 1GB. Take 2 X 512MB sticks, put them on the first and third Ramslot and fly in dual channel mode.
Also if 1 of ur modules go bad, u still have 512MB as backup 4 sometime.
maheswar2006 is offline
Old 17-04-2006, 12:49 AM   #10 (permalink)
And if the budget permits, go for the SUPER LANBOY cabinet from ANTEC and get an ANTEC SMARTPOWER2 or TRUEPOWER 400W at least.
U will NEVER regret it.
