Old 15-04-2006, 02:15 PM   #1 (permalink)
Default web cam!!
Hi guys,i want to purchase a decent web camera working at atleast 30 fps
and resolution upto 640x480..Can you suggest something which is readily available? My Budget is 1500
josh_nitb is offline
Old 15-04-2006, 07:41 PM   #2 (permalink)
Wandering in time...
Ankur Gupta's Avatar
go for logitech quick cam it is cheap and meets ur requirements.
btw a thread already running for this chk befor posting
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 15-04-2006, 09:22 PM   #3 (permalink)
ambrewz's Avatar
Default Fine choice
yeah I agree to the Above post ... I am personally using it ... Works Fine for ME
:Techno::Qdalz:
ambrewz is offline
Old 16-04-2006, 12:39 PM   #4 (permalink)
samrulez's Avatar
You can go for a ligitech cam.Creative products are better but expensive.
It costs 5000 bot it has a 1.3 megapixel camera and you can capture video at 640x480 at 30 fps.I have it,it rocks.The quality is as good as a digi cam.
samrulez is offline
