Old 14-04-2006, 04:54 PM   #1 (permalink)
ritwickgupta's Avatar
Default dual core processor???
wot exactly is a dual core processor n is it really worth going for it????
i also need a comparision like amd single core 3500+ = X%age of amd dual core 3800+
plz help me guyz......think it will help a lot of ppl out here
happy computing
ritwickgupta is offline
Old 14-04-2006, 05:00 PM   #2 (permalink)
mayanksharma's Avatar
A dual-core CPU combines two independent processors and their respective caches and cache controllers onto a single silicon chip, or integrated circuit. IBM's POWER4 was the first microprocessor to incorporate 2-cores on a single die. Various dual-core CPUs are being developed by companies such as Motorola, Intel and AMD.
And yeah it is really worth going for!though they are costly, but the performance gain over the single core chips is awesome.
mayanksharma is offline
Old 16-04-2006, 07:00 PM   #3 (permalink)
samrulez's Avatar
Default Reply
Dual Core Processors are use full for multi tasking.They have 2 cores with 2 caches.Go for an AMD 3800+ dual core processor if you will multi task.Remembe in dual core processors you can open a number of applications at the same time without compromising on the speed.
samrulez is offline
Old 16-04-2006, 09:42 PM   #4 (permalink)
Learner
Kniwor's Avatar
Default Re: dual core processor???
this comparison is not probably the best way to do
a 3800+ is basically two 3200+ inside it... so now how will u compare...
for all single threaded apps it will be equal to a 3200+, all benchmarks like super pi etc will give the same results as a 3200+ but it is not the same as a 3200+...
at the same time it has 2 3200+ does not make it doule that
hope u get my point
Kniwor is offline
Old 17-04-2006, 03:11 PM   #5 (permalink)
samrulez's Avatar
Don't og for AMD x2 3800+,I suggest wait for around for 5-10-29 yrs.Then go for the IBM cell processor,well it's not a dual core processor but has only 9 cores............................................. ..just kiddin!
AMD Athlon X2 3800+ is not a bad deal
samrulez is offline
