Old 12-04-2006, 04:19 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default ~~{serious cd burning problems ! ! ! !
am having various problems my combo drive like
#not able to write over the speeds of 16x; it gives burn process failed !
#even at speed of below 16x the cd is not burned correctly & can not be read from other computer;it causes computer to hang or cd files are shown empty via windows explorer;however there is no error msg during burn time.
#if by chance a cd is corretly burned and is readable on other computer;then is can't be copied;the error supllied is INVALID MS-DOS FUNCTION or DATA REABUNDANCY OR CYClic ERROR
#if some disc's have very little scrathes is also not read means i can't copy it.however i tried the same cd on my friends computer who has exact the same combo drive in model no.
i have a athlon 3000+,msi-k8m800,SATA hard drive,sony combo,win-xp-sp2,nero-6.3,
gary4gar is offline
Old 12-04-2006, 04:27 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
log of nero
gary shah
HOME
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 4:33:44 PM
Nero version: 6.3.1.20 (Nero Express)
Recorder: <SONY CD-RW CRX320E> Version: NYK5 - HA 0 TA 0 - 6.3.1.20
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY CD-RW CRX320E >Version: NYK5 - HA 0 TA 0 - 6.3.1.20
=== Scsi-Device-Map ===
CdRomPeripheral : SONY CD-RW CRX320E atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST380817AS 3.42 viamraid Port 2 ID 2 DMA: Off
=== CDRom-Device-Map ===
SONY CD-RW CRX320E G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 32505856 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 191MB (196080kB)
Free physical memory: 46MB (48020kB)
Memory in use : 75 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.4.2006
CD-ROM (ISO)
3:58:13 PM #1 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
3:58:13 PM #2 Phase 96 File dlgbrnst.cpp, Line 1855
Buffer underrun error protection activated
3:58:13 PM #3 Text 0 File Reader.cpp, Line 126
Reader running
3:58:13 PM #4 Text 0 File Writer.cpp, Line 124
Writer SONY CD-RW CRX320E running
3:58:14 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
3:58:14 PM #6 Text 0 File Burncd.cpp, Line 3173
Turn on Track-at-once, using CD-R/RW media
3:58:58 PM #7 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 333749 ( 74:11.74)
Last address to be written: 254938 ( 56:41.13)
3:58:58 PM #8 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
3:58:58 PM #9 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: SONY CD-RW CRX320E;
CDRW code: 00 97 27 00; OSJ entry from: DIGITAL STORAGE TECHNOLOGY CO.,LTD
ATIP Data:
Special Info [hex] 1: B3 00 CE, 2: 61 1B 00 (LI 97:27.00), 3: 4A 0C 00 (LO 74:12.00)
Additional Info [hex] 1: 24 1A D8, 2: 26 B2 4A, 3: 00 80 80 (invalid)
3:58:58 PM #10 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
This disc is not empty.
(Medium in drive: Unknown. Medium required by compilation: CD-R/RW.)
Disc was erased successfully.
Accessing disc...
3:58:58 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 254939 (254939) = #254939/56:39.14
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 254937 blocks [SONY CD-RW CRX320E ]
3:58:58 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [SONY CD-RW CRX320E ] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 522422272, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
254939 | lead-out | 1 | 0x00 | 0x41
3:58:58 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 254939 -> 254937.
3:58:59 PM #14 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
3:58:59 PM #15 Text 0 File Burncd.cpp, Line 4183
Cache writing successful.
3:58:59 PM #16 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
3:58:59 PM #17 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 10x (1,500 KB/s)
3:58:59 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:58:59 PM #19 Text 0 File Mmc.cpp, Line 20531
Set BUFE: Buffer under-run error protection -> ON , SMART-BURN : ON
4:04:40 PM #20 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
4:04:42 PM #21 Text 0 File Mmc.cpp, Line 15356
<SONY CD-RW CRX320E > start Close Session
4:04:58 PM #22 SCSI -1176 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x00
4:04:58 PM #23 CDR -1176 File ThreadedTransferInterface.cpp, Line 1183
Session fixation error
4:04:58 PM #24 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 1183
Could not perform Fixation
4:04:58 PM #25 Text 0 File Mmc.cpp, Line 15356
4:04:58 PM #26 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
4:04:58 PM #27 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 10x (1,500 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 10/27/2005 1:42:48 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[edit]:-removed serial no.
gary4gar is offline
Old 12-04-2006, 04:34 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
i tested my combo in nero cd/dvd speed
here are some results
gary4gar is offline
Old 14-04-2006, 05:21 PM   #4 (permalink)
mayanksharma's Avatar
Go and upgrade your writer's firmware. That should help!
If it doesn't then, simply go for another replacement.;D
mayanksharma is offline
Old 14-04-2006, 05:35 PM   #5 (permalink)
tiblu's Avatar
Try changing the IDE cable or set CDRW to Master Channel
tiblu is offline
Old 15-04-2006, 01:34 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
i mentioned that i hav a sata hard disk so it implies that cd-rw is set to master only as i don't hav another hdd.also i tried chaninging the cables also but no help
gary4gar is offline
Old 15-04-2006, 09:20 PM   #7 (permalink)
just get a lens cleaner cd for 50 bucks
kundra.nitin is offline
Old 15-04-2006, 09:34 PM   #8 (permalink)
dIgItaL_BrAt's Avatar
@gary4garlease remove your Nero serial number (1AXX-XXX...) from your post.
dIgItaL_BrAt is offline
Old 16-04-2006, 10:59 AM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
@digital_brAt
thanx
any more solutions pls?
my drive is in warranty period should i get it replaced.
IS this covered under warranty???????
gary4gar is offline
