Old 11-04-2006, 09:27 PM   #1 (permalink)
kool's Avatar
Default KEYBOARD+MOUSE problem!!!!
i've samsung multimedia keyboard, now its 3 year old....... sometime its NUMlock light get ON, and
freeze my all buttons for few seconds, and sometime CTRL button get auto ON, whenver i type anything
it start beep sound.... Shoud i buy new keyboard or something wrong from my PS/2 cable?? or
motherboard is faulty??
and also my optical mouse sensor is not working good.... it is not working on plane plywood surface of
table, but working fine on any card-board/little rough magazine/ Greeting cards/textbooks etc.
i mean it working good on little rough surface, i'm facing this problem from 3months... my mouse is 3
year old!! Is censor can be changed by any computer mechanic????
or shoud i buy new???
if yes in both case, then plzzzzzzzzzz tell me lowest price of optical mouse nad any type of keyboard!!
►► ◄◄ :smile::smile:
kool is offline
Old 11-04-2006, 10:08 PM   #2 (permalink)
ASH_DSG
Posts: n/a
HI,
U cn check the wire of ur mouse and keyboard if they r not break internally try to change them if u like ur mouse or keyboard. If u have a budget of Rs. 800-1000 then u can buy new optical mouse and multimedia keyboard of any company.
Old 11-04-2006, 10:09 PM   #3 (permalink)
ASH_DSG
Posts: n/a
U should buy new one now.
Old 11-04-2006, 10:28 PM   #4 (permalink)
sknowonweb's Avatar
ya but dont need to invest that much . Both can be handled within 500bucks.
it is more advisable to use non multimedia keyboard as it is cheaper and cheap enough to throw away when u find it is faulty.
go for MM Kboard only if u find it useful to use that extra butts other than volume and mycomputer.
Regarding mouse , worth to replace one.
sknowonweb is offline
Old 11-04-2006, 11:43 PM   #5 (permalink)
Samung suck in KB + Mouse products
Samung is best in Monitors + webcams
You can get a new Multimedia KB + Optical Mouse COmbo from Adcom Rs 399/- and its much better than Microsoft basic MM Keyboards.
Rajesh_81 is offline
Old 13-04-2006, 10:49 PM   #6 (permalink)
kool's Avatar
wat is mode no.?
kool is offline
