Hi guys, One of my friend called me up now and he's going to buy a mobo processor and ram . his budget is 12000/- .He will be calling in another 30 mins with the price details. i have sugested him to go for AMD+MSI combination .
I have sugested AMD 64 3000+ -- approx 5000k
and MSI mobo --- dono the cost.
And yes should have a onboard video.
Please reply immediately of any other options.
@varun
u are suggesting him motherboards which does not have any integrated graphics.... which means he will have to purchase a graphics card also and i dont think he intended to get into all this....
@charangk
do u have extra budget for graphics cards..... if not.... just ignore varun's post and rest is fine......
if u alread have a graphics card and want to use it, and if it's a PCI-E card.... ASUS A8N-SLI is option worth considering but i would still not suggest the board.... there is no point getting SLi...... it's waste... just get the non SLI version ASUS A8N-E....... this will save around 1200-1300 which u can spend extra on ur graphics card......
if u have a graphics card and is AGP.... nothing above holds.... u need a card with AGP slot... post back then
I mentioned in the very first post the it should have a onboard video . I had spoke to varun and i forgot to mention this so it was my mistake . he told that his mobo was based on ATI chipset and i wanted him to post it here with some approx prices .
Please read my post carefully... I have mentioned MSI RS482 in the very beginning taking care of onboard graphics needs... Then i have mentioned the best of mobo in line so that charangk will know what he is suggesting to his friend... We had telephonic conversation and considering his needs i have suggested the mobos...
However i would also like to mention here that most of the times computer is purchased at a price more than allocated price... And somewhere the suggested mobos may make its way while purchasing...
@charangk
I would that MSI RS482 M2IL is based on ATIs RS480(2) chipset.. May other compaines such as ASUS, ASROCK have their own models based on this chipset and are priced below MSI RS482 M2IL but the performance is unparalled to MSI.
Also nvidias chipset are also very good and do check them........
thanks for the info varun . i explained these to my friend and he is gonna buy a AMD 64 3000+ and the MSI board. he just waiting for the tension in bangalore to go down a little. Most of the shops are closed for now.
