Hi all,
can someone tell me the difference between the Pentium 8XX and the 9xx series.And how much is the cost difference between the two,Specially between 830 and 930.Thanx
ok listen , out of the 800 and 900 series .. the 900 is much better .. as it is a presler core cpus with 65 nm fab process with large 4 mb L2 caches ..
they perform much better than 800 series and dont heat like 800 series .. i mean they run relatively pretty cool ..
now there's a catch .. there is a new 805 pentium d .. which is 2.66 ghz 533 fsb with total 2 mb cache buffer dual core cpu .. its like 6.5 k in price and performs good too .. and its overclocks well too ..u can go for it if short on budget '
also 920 .. 2.8 ghz 800 fsb 4 mb L2 cache is damn good .. performs well and overclocks very well .. 13.5 k or something ..
Does anyone has a better idea of the prices of 830 and 930.And i have heard of heating issues with both the 8xx and 9xx series.Which one is better in that case.And if put Against AMD X2 3800+(Manchester) Which is the better choice.My budget for the Processor is 10-12k max.
AMD X2 3800+ will be a good choice
BUt any ways if u still want pentium then go for...
920 D processor. no matter if it cost 13000 or abt tht much...
It will be grt in future.... http://www.intel.com/products/proces...um_D/index.htm
check this...
Here u will find compare specification index
just click tht link
DusT = ME
Fine just seen the updated site of deltapage..The x2 3800+ costs 16k. good price drop
BTW delta page has been finally updated after a month but there is one thing thats pissed me off. This mobo gigabye k8n51gmf9 now costs 3750. I purhcased the same at 5k just two months off.
Sorry if i went off topic..just couldnt stop
