Old 08-04-2006, 09:01 PM   #1 (permalink)
go_gamez's Avatar
Default suggestions :help to upgrade my pc!!!
hi all u tech folks!!
my current system config. is as follows:
P4 2.4 ghz 1MB L2 cache 533 mhz bus
HIS motherboard 845 GVM-L
256 MB OF DDR RAM
80 gb seagate HDD
LG CD WRITER AND A CD-ROM
GE-FORCE MX4000 128 MB AGP CARD
2.1 INTEX SPEAKERS
i want to upgrade my PC as follows- (IF POSSIBLE BELOW 22K)
1GB OF DDR RAM
A BETTER AGP CARD OF 256 MB ON WHICH I CAN PLZY ALMOST ALL GAMES (between 5K-8K)
SECONDRY HDD (40 GB or 80 GB)
4.1 OR 5.1 SPEAKERS (4K-5K)
A DUAL LAYER DVD WRITER
ALL THE HARDWARE SHOULD OF A GOOD BRAND(NOT VERY HI-END) AND NOT BURN A HOLE IN MY POCKET!!!
PLZZ SUGGEST ME THE MODELS WHICH I SHOULD BUY AND WHAT WILL BE THE APPROX. PRICES!!!!
HELP ME!!
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 08-04-2006, 09:13 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
RAM 1GB DDR ram - that is ur choice ...keep it as last option depending on how much money u have left aftre getting remaining stuff (aprox 4K) i may be wrong check out...
Y ur going for 256 mb card , wasting the extra 1.5 to 2K, instead for 126MB 6600GT, u can play all latest games, agp is arnd 8k to 8.5K,......
go for 80Gb hdd if ur mobo supports 160 GB hdd else stay with 40GB.....company ur choice
5.1 speaker - can go for creative......does ur mobo has 5.1 suppport else u haev to buy sound card
dunno much abt DUAL LAYER DVD writer .... but benq writer r good then liteon then sony....i bought benq DW1650 for 2.7K
wizrulz is offline
Old 08-04-2006, 09:13 PM   #3 (permalink)
ymhatre's Avatar
DO u want to upgrade ur mobo....
I think ur mobo is too old n will be outdated.. soon
think of getting mobo with pci express slot....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 08-04-2006, 09:13 PM   #4 (permalink)
ID SUGGEST U GO FOR A NEW CPU SET UP ANY WA U NEED TO CHANGE BEVERYTHING
madhan is offline
Old 08-04-2006, 10:13 PM   #5 (permalink)
go_gamez's Avatar
Default cpu??
can u build me a new cpu under 20 k???
a good one
512 MB DDR RAM .
go_gamez is offline
Old 09-04-2006, 11:17 AM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
what r ur needs? gamer?....casual user? etc?
wizrulz is offline
Old 09-04-2006, 08:59 PM   #7 (permalink)
yes change ur mobo
go fr simple 915 bord
P III 600 Mhz, GeForce 2 MX, Samsung Samtron 45B(n), Zoltrix 4 Channel Sound, Hynix 256 MB SDRAM 133 MHz, Samsung SM 352 BM Combo Drive
Since every dog has its Day
I will have mine too
saketkutta is offline
Old 10-04-2006, 02:07 PM   #8 (permalink)
Default Re: cpu??
a good one
check this http://tech2006.zeeblo.com/Guides.htm
Rajesh_81 is offline
