Old 08-04-2006, 07:27 PM   #1 (permalink)
shovik's Avatar
Default 6600GT problem
I have a configuration of intel 865GBF motherboard, 1GB RAM, 80GB SATA HDD, 2.4GHz intel processor with a 300Watt SMPS. Recently I bought a XFX 6600GT AGP 256MB graphics card. I installed the card along with the latest Nvidia forceware driver 81.98. I had formatted my harddisk prior to the installation of the card. The problem I am having now is that whenever I enter into a game, after sometime my monitor freezes and my PC hangs. The only way out is to reboot.
Please let me know if the problem is from my graphics card, the power supply or anything else I need to do to overcome this problem.
Please help me out....
shovik is offline
Old 08-04-2006, 07:43 PM   #2 (permalink)
Default hi
dear shovik,
I think your powersuply is not upto the mark plz check your system with 400w.
goman is offline
Old 08-04-2006, 08:01 PM   #3 (permalink)
shovik's Avatar
Default reply
don't get me wrong but are you sure that its the power supply because if it is then I have to buy a new one.
shovik is offline
Old 09-04-2006, 01:27 AM   #4 (permalink)
Dark Overlord !!!
rockthegod's Avatar
yes, u need to hv at least a 400 W Power Supply Unit (PSU) [thtz of ne general company like Frontech etc etc] or u can rely on an Antec 350W PSU safely.
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 09-04-2006, 01:32 AM   #5 (permalink)
mayanksharma's Avatar
Simply go for Coolermaster Real Power 450W or Antec Power supply with atleast 400-450W and everything will be fine!!
mayanksharma is offline
Old 09-04-2006, 01:53 AM   #6 (permalink)
Learner
Kniwor's Avatar
well i will fist wana test the PSU befor spending money ona a new one.... although i also tink that PSU could be a problem... freezing often happens when it's the PSU...
remove a ram module, remove any fans other than cpu fan....
remove ur cd/dvd drive ur floppy drive... and usb peripherals any slave HDD... or anyhting else that is not required for the system to boot...
now try playing the game... if it works fine.... get a new PSU...
if i still freezes.... post back here
Kniwor is offline
Old 09-04-2006, 06:08 AM   #7 (permalink)
mav3r1ck's Avatar
Default Re: 6600GT problem
@shovik, i would second what knivor said.
BTW how much did it cost u i was thinking of buying a new one.
.....i have seen god, he plays as a chelsea striker.....
mav3r1ck is offline
