Old 08-04-2006, 12:23 PM   #1 (permalink)
Default ASUS A8N-SLI Deluxe..........NO AGP ???
ASUS A8N-SLI Deluxe
http://www.cdrinfo.com/Sections/Revi...12466&PageId=0
THIS HAS NO AGP ???....
vinyas is offline
Old 08-04-2006, 01:45 PM   #2 (permalink)
So, most of asus motherboards dont have an onboard GPU , you have to add a card for that.
cyrux is offline
Old 08-04-2006, 05:13 PM   #3 (permalink)
no dude .... i am askin whether is supports Agp card ??
vinyas is offline
Old 08-04-2006, 05:30 PM   #4 (permalink)
No it dosen't support AGP. You can only add a PCI Express graphics card.
drvarunmehta is offline
Old 08-04-2006, 05:34 PM   #5 (permalink)
i mean there is no Onboard graphics ??? need to buy a Pci-e Graphics Card ..?
if so recommed be good mobo for Amd x2 3800 +
pls be specific on the model ....
vinyas is offline
Old 08-04-2006, 06:08 PM   #6 (permalink)
Learner
Kniwor's Avatar
u are really confusing...
anyhow it does not have any onboard graphics... neither it support agp card...
u got a agp card or something....
do u want a board with onboard graphics ... or do u want to user ur current agp card... please be specific
Kniwor is offline
Old 08-04-2006, 06:20 PM   #7 (permalink)
since i wont be a heavy gamer .... i dont need a multilple graphics mobo... instead i would prefer some onboards graphics ...so i need help on this now ....
same features as ASUS A8N-SLI Deluxe minus multiple graphics instead some onboard graphics ...
vinyas is offline
Old 08-04-2006, 07:54 PM   #8 (permalink)
The best mobo with onboard graphics for a X2 3800+ would be the Asus A8N-VM.
You can't get the same features as the Asus A8N-SLI Deluxe along with onboard graphics. This is a really high end mobo and some of its features can't be found on low end boards (ie with onboard graphics).
Old 08-04-2006, 08:10 PM   #9 (permalink)
thnk
Best Mobo WITHOUT ONBOARD GRAPHICS... (NOT DUAL)
vinyas is offline
Old 09-04-2006, 12:06 AM   #10 (permalink)
Learner
Kniwor's Avatar
If u are not a gamer why do u want a SLI mobo.... when u are not willing to purchse even 1 graphics card why do u want place for 2....?????
get ASUS A8N-E it has less features than the SLI version but is based on nForce 4 ultra... and is also quite feature rich, moreover it has 4 PCI slots so u can always add things ic u want..... with 10 USB ports u will never have to waste a PCI slot on usb etc....
this will be much much cheaper tha the SLI version and also good at the same time
another good option is DFI Lanparty UT nF4 Ultra-D, see if u can get.....
Kniwor is offline
