Old 06-04-2006, 08:07 AM   #1 (permalink)
thetopcyborg's Avatar
Default Pc strictly under 25k
hey all you guys, i am going to upgrade my pc and literally buy a new one....so please suggest me some good specs...these things should be a must....
1GB RAM
a 17" TFT monitor
a real fast processor for gaming...
PCI-e architecture motherboard
256MB graphics card pci-e(of course)...i want to do some heavy gaming like Unreal Tournament 2004 and the future UT2007
now for the doubtful part....should i go for a AMD based or Intel based computer...i am really avid gamer and also create flash animations ...i will move on to 3D modelling once a new machine comes.....and i have heard that amd is good for gaming and intel for animations and like....so please suggest for what should i go........
also, the computer must be Vista-compatible....
the budget should not exceed 25000 at all....i am buying it after about two months, so you can give some future suggestions......i am asking you about the specs early as i have to start researching from now....
one more thing, it should be comfortable with new games and softwares for about 2 years....
thanks in advane
thetopcyborg is offline
Old 06-04-2006, 08:33 AM   #2 (permalink)
add to the list...
a good power supply
a DVD writter with lightscribe
speakers 5.1
sound card, if the mobo soesn't support 5.1 channel
a gamer's cabinet or any classy, sleek and sexy cabinet like the one from 'i'
the mobo must contain upto 8 usb computers...
thanks again....fastttttttttttttt, reply
Old 06-04-2006, 11:35 AM   #3 (permalink)
Add to the list another 10k atleast
cyrux is offline
Old 06-04-2006, 02:52 PM   #4 (permalink)
gooby pls
Third Eye's Avatar
Add 20 K to your budget !
I bought my midrange pc around 40 K with no monitor,no mouse,no keyboard.
Third Eye is online now
Old 06-04-2006, 05:18 PM   #5 (permalink)
If the 17" TFT alone takes up more than half your budget, how do you expect to be able to afford all this in 25k? You need to increase your budget by atleast 20k.
drvarunmehta is offline
Old 06-04-2006, 09:28 PM   #6 (permalink)
ymhatre's Avatar
Lets Try things out...
Suppose u have 35Ks right...
Consider SamsungS TFT monitor 17" - 713N--> 13500
512*2(400) around----. 4500
ASUS P5Rd2 + Intel 3.0 Ghz HT 2 mb ---> 12000
_______________________________________
This Makes 30000RS...
NOw DVD writer----> 3000Rs....
And 2000 for good CAbinet with 450 watt SMPS..
Complete 35000 Rs
Wait for graphic card prizes will be down sooner...
Till then the mobo has good Inbuilt ATi X 300 GPu...
I guess theres no need of 5.1 speakers
i mean these stuff r not one time investmest..
U can later add 5.1
Also DVD With Lightscribe wont fit into ur budget u will need 3ks more for this...
mobo supports 6 channel...
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 07-04-2006, 10:24 AM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
is this u call a pc ? ?
gary4gar is offline
Old 07-04-2006, 10:27 AM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
hey if i go for a normal CRT b'cos
worst CRT is better than best lcd.
gary4gar is offline
Old 07-04-2006, 10:38 AM   #9 (permalink)
ashfame's Avatar
Mine suggestion no different from above.
My friend just bought a PC with almost about your configuration maybe a little more and it cost him around 60k as he had bought it from HCL.
ashfame is offline
Old 07-04-2006, 11:28 AM   #10 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Pc strictly under 25k
1GB RAM
a 17" TFT monitor
thanks in advane
R u kidding
U wanna go on world tour on a budget that is just sufficient for india tour
No hard feelings .....but if u want that all stuff increase ur budget
wizrulz is offline
Old 08-04-2006, 09:29 PM   #11 (permalink)
thanx for the suggestions....i think i will drop my TFT (sigh!!!!).....maybe things would change in two months....thanx again for wasting your time on me
Old 09-04-2006, 12:10 AM   #12 (permalink)
Learner
Kniwor's Avatar
Let us see
Samsung syncmaster 793 DF ~6400
AMD Athlon 64 3200+ ~8000
1 Gb Hynix ram ~4000
80Gb HDD ~2000
KB+Mouse+cabinet ~2000
we got only 3000 left for the mobo... so u see the problem here dont you...
now if we get 512 Mb ram and say u can add 512 Later...
then we got 5000 left for board which can get u a decent board with onboard graphics and PCI-E slot so that u can add a PCI-E card for ur gamin needs....
Kniwor is offline
Old 09-04-2006, 01:07 AM   #13 (permalink)
mayanksharma's Avatar
ok
considering your budget here is a very rough and approximate layout:-
15"TFT from BenQ
Samsung 40/80GB hard drive
256x2 MB dual channel
AMD 3000 64+ with asrock or winfast with onboard
6200 pci turbo card with shareable memory
Intex/Mercury/Samtech/TechCom 5.1 speakers low end models
Choose 250-300W power supply from coolermaster/Mercury
And go for LG DVD writer or the one from Kiobe
and choose cabinet from iBall.
and now two things from me:-
Either you dont know anything about the pc or you are joking with all the guys around.
Look man let me give you one piece of advice,
for running vista on your machine smoothly you should atleast have 2GB of RAM on ur system!
Regarding your specifications you have mentioned everything that a decent computer should contain.
So, my friend, atleast increase ur budget by 15000-20000/-!
And i'll promise. that you will get nothing but the best system of your choice, with all of our best comments added to it.
Even personally i'll help you build the rig.
mayanksharma is offline
Old 09-04-2006, 02:42 AM   #14 (permalink)
Originally Posted by Kniwor
Let us see
80Gb HDD ~2000
Thats the best thing...go for the Ram later, u can always do that.. Invest on a better mobo. One more thing..My friend got a samsung syncmaster (dont remember the model no.) 17" for 4100
cyrux is offline
Old 09-04-2006, 10:04 AM   #15 (permalink)
Learner
Kniwor's Avatar
yeah he mush have got a non flat one.... they are cheaper....
the one i am suggesting is Dyna flat...
Kniwor is offline
Old 09-04-2006, 01:13 PM   #16 (permalink)
Right , right...my friend has a non flat one..missed out that point....but still looks pretty good
cyrux is offline
Old 28-04-2006, 11:47 PM   #17 (permalink)
Pharmaguru
kjuvale's Avatar
I jsut bought new syncmaster 798mb plus-
Its flat with magic brigh absent in dynaflat(DF) series and also with magic green (biorays). very good monitor at 6500
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
