Old 05-04-2006, 12:20 PM   #1 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default PENDRIVES REPAIR
Can Pen drive be repaired? I have a samsung pendrive which suddenly fails to detect but the light on it glows :roll:
So i wanted to knwo where i can repair it in MUMBAI
I dunno but from march many of my PC components r crashing......first web cam, then CD-r rom, and now pen drive may be this is last one
wizrulz is offline
Old 05-04-2006, 12:54 PM   #2 (permalink)
Try formatting it with the samsung software you got
cyrux is offline
Old 05-04-2006, 02:28 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
To format the drive, it should first get detected na
wizrulz is offline
Old 05-04-2006, 03:12 PM   #4 (permalink)
Ok, so u mean it doesnt get deteted at all. Try this .. m not sure if it works. There must be some loose connection between flash and porrt. After inserting the flash just move it around little bit to see if it gets detected
This happened to me with my flash, but if your light is glowing and flash doesnt get deteched then the prob. might be somethign else
cyrux is offline
Old 06-04-2006, 11:24 AM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Does any1 has solution for this problem ?
Has no one faced such a problem before ?
Please do help me with this one atleast, have to get one of- cd rom or pen drive working urgently
wizrulz is offline
