Old 02-04-2006, 06:48 PM   #1 (permalink)
Default can LCD Monitor needs different port for plug in mainboard ?
can LCD Monitor needs different port for plug in mainboard ? I'm lil bit confuse over this. I'm planning to asemble new pc and I don't know thsi that cRT and LCD use same plug or different
MasalaStation.com
myhotdog is offline
Old 02-04-2006, 07:08 PM   #2 (permalink)
mayanksharma's Avatar
LCD uses DVi connector where as CRT uses analogue connector.
If you are going for LCD then make sure to have DVI connector on your display card.
otherwise you can purchase DVI to analgue converter port from anywhere.
In most of the caeses this converter comes bundled with graphics cards or with LCDs.
mayanksharma is offline
Old 02-04-2006, 08:21 PM   #3 (permalink)
not ALL lcd's use dvi connectors
mostly the lcd ull get will be VGA unless u ask for a dvi cuz most lcd monitors are analog and not digital
No Mercy, No Limits.
theraven is offline
Old 02-04-2006, 08:40 PM   #4 (permalink)
l
Infact Very less LCDs use dvi connectors
cyrux is offline
Old 02-04-2006, 09:03 PM   #5 (permalink)
then I shuld by motherboard which has DVI connector
tell me motherboard which has DVI connector for AMD 64 3200+ 939 pin
or tell me LCD monitor which has VGA connector
MasalaStation.com
myhotdog is offline
Old 02-04-2006, 10:28 PM   #6 (permalink)
All LCD monitors can use VGA input. Even if the monitor has a DVI input, you can use the DVI to VGA connector to use it on a VGA port.
drvarunmehta is offline
Old 02-04-2006, 11:08 PM   #7 (permalink)
ymhatre's Avatar
ASUS VM CSM has a DVI-D port with it..
DusT = ME
Rate me if was clear to you
ymhatre is offline
