@ymhatre definetly taking a SATA 2 will be good if u ever upgrade ur mobo u will not need a HDD upgrade for higher speeds just adjust the jumphers.
@medigit buying a large HDD is always good. I would suggest u to get the biggest HDD which u can afford. Whatever is the size of HDD one day u will feel it is small.
