Old 01-04-2006, 12:28 PM   #1 (permalink)
ASH_DSG
Posts: n/a
Default DUST IN CABINET
Hi friends,
I have a 80mm fan which suck air from outside through which dust also came in to my cabinet and fan also covered with dust can u help me how could I prevent dust to came inside my system
Old 01-04-2006, 01:09 PM   #2 (permalink)
The pWnster
Vyasram's Avatar
i dont think u can prevent it but u can clean it
Keep it in a clean environment pref ac.
Sigs suck
Vyasram is offline
Old 01-04-2006, 07:00 PM   #3 (permalink)
i think the FAN should be in opposite direction for better cooling
ashnik is offline
Old 01-04-2006, 07:47 PM   #4 (permalink)
nishant_nms's Avatar
The fan is on the front or rear
nishant_nms is offline
Old 01-04-2006, 08:20 PM   #5 (permalink)
phatratt's Avatar
make sure u have atleast two fans for cooling one for intake and the other for exhaust.Also,don't place u'r PC in a dusty environment.
phatratt is offline
Old 01-04-2006, 08:48 PM   #6 (permalink)
ymhatre's Avatar
HOw do we know whether the applied fan is working as a cooler ie sucking air inside or exhaust ie throwing air outside...
n also where to place which fan.
i mean in front pannel which fan also in rear pannel which fan...
also a t side which fan shld be applied....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 01-04-2006, 10:02 PM   #7 (permalink)
Technoholik !!
Tech&ME's Avatar
@ASH_DSG
Better you remove the inlet fan completely from your PC CASE. It must be located in the front panel grid from inside the cabinet. (Below the harddisk).
Remember : Always use an inlet FAN only if you are working in an Air-conditioned room, otherwise you should never use it at all.
To clean the CASE anyway, use a blower (light speed) to blow off the dust.
Tech&ME is online now
Old 01-04-2006, 10:18 PM   #8 (permalink)
ymhatre's Avatar
thnx for the info
DusT = ME
ymhatre is offline
Old 01-04-2006, 10:19 PM   #9 (permalink)
ymhatre's Avatar
thnx for the info @ TECH ME
DusT = ME
ymhatre is offline
Old 01-04-2006, 10:33 PM   #10 (permalink)
Pardon me for m ignorance but can you explain why shouldnt there be a fan for inlet circulation of air without an AC ?? Most people dont have ACs so they work around with the fan quite conveniently
cyrux is offline
Old 01-04-2006, 10:40 PM   #11 (permalink)
ymhatre's Avatar
Actually i agree with wht TECH & ME said...
working with an inlet fan in non ac can introduce hot air inside the cabinet..
thus increaing the temperature...
But on the other hand if the pC is placed near by a common ceilling fan, then tht will do
Actually inlet fan blows the air having room temperature, inside the cabinet..
IF ur room is hot then such fans r not prefered..
Instead blowing out fans hold good at such places..
DusT = ME
ymhatre is offline
Old 02-04-2006, 08:42 AM   #12 (permalink)
Technoholik !!
Tech&ME's Avatar
Hope you got your answer now.
This is one of the reason no one provides an inlet fan pre-fitted with a cabinet when you purchase them. However, some cabinet do come with a rear outlet fan already fitted on to it.
Old 02-04-2006, 07:34 PM   #13 (permalink)
darklord's Avatar
Well cleaning your Case interiors with a domestic blower once in a week helps maintaning your PC and keeping it in good shape.
darklord is offline
Old 02-04-2006, 08:47 PM   #14 (permalink)
Once a week, thats too much work for me ... i dont do it even once in 6 months...lol
cyrux is offline
Old 02-04-2006, 09:25 PM   #15 (permalink)
ymhatre's Avatar
Take My words
Not cleaninng ur Pc in 15 days will definately reduce the life span of it..
DusT = ME
ymhatre is offline
Old 02-04-2006, 10:02 PM   #16 (permalink)
JGuru's Avatar
First of all keep your PC in a dust-free room. If your
PC is in the second room, don't open the second room's
Windows. Open only the first room's Windows. I think
the main problem in your case is that the room gets
lots of dust. Also clean the cabinet with a air-blower
atleast once in a month. Also make sure the room
is well-ventilated.
JGuru is offline
Old 02-04-2006, 10:26 PM   #17 (permalink)
::vicky::'s Avatar
vaccum cleaner or air blower is also good
::vicky:: is offline
Old 02-04-2006, 10:31 PM   #18 (permalink)
You mean opening it up and cleaning it ?? sounds a tedious task...
cyrux is offline
Old 02-04-2006, 10:44 PM   #19 (permalink)
ymhatre's Avatar
how much time does it take to unwound two screws n lift out side pannel...
I dont think thts tedious job....
DusT = ME
ymhatre is offline
Old 03-04-2006, 08:51 AM   #20 (permalink)
Eazy's Avatar
Vacuum cleaners with their fast air suction create a lot of static electricity which gets concentrated on the tip of the hose - take care not to let the the tip near any parts in the case sensitive to static electricity - an answer I came across was to wrap the tip of the hose with cardboard thus keeping the tip away from the chips and CPU and ram.
Also make sure the air flow does not make the fans inside the case spin wildly as they can get damaged when they are spun at very high speeds.
Just my Re 0.02
Eazy is offline
Old 03-04-2006, 08:57 PM   #21 (permalink)
ymhatre's Avatar
Hmm i do agree with wht EAZY said..
I had forgotten to tell this, even i use my vacuum cleaner at low folw while cleaning electronics..
Also i wear an anti static belt at my wrist while cleaning this devices..
though this belt is not reqiured..
DusT = ME
ymhatre is offline
Old 03-04-2006, 11:03 PM   #22 (permalink)
lol...tedious task to open it up ???
anyways i keep my cabinet naked all times!!
grinning_devil is offline
Old 06-04-2006, 07:20 AM   #23 (permalink)
ymhatre's Avatar
i dont understand this...
why its tedious to remove 2 srcew to side pannel...
n atleast clean the dust inside the cabinet with dry n clean cloth...
@g... devil
as u earlier said tht ur temperature of pc is much higher...
so u r making u cabi naked otherwise its not preferable to do so...
DusT = ME
ymhatre is offline
Old 06-04-2006, 08:36 AM   #24 (permalink)
yeah i know man,but i'll prefer a small drop in temp,and for that even if it requires a weekly clean i wont mind...
ntw, my PC resides on a clean area..no dust....no cleaning for atleast 1 month!!
Old 06-04-2006, 11:09 PM   #25 (permalink)
I have got 2 fans tomorrow and connected it my PC the fanon the back draws the air out of the cabinet and another is on the side panel which sucks air inside. My cabinet has no place to add a fan in the front. I want to know that I had connected the fans in right way
Old 07-04-2006, 07:00 AM   #26 (permalink)
ymhatre's Avatar
Yup u hav connected the fan in right way
DusT = ME
ymhatre is offline
Old 07-04-2006, 01:00 PM   #27 (permalink)
Jai Suresh
lywyre's Avatar
if you are in a dusty env, then just keep the side cover open, the pc is going to get dusty anyway. By keeping open, atleast the temp will be kept low.
Also don't use powerful vacuums, they could blow away some delicate components
lywyre is offline
Old 07-04-2006, 09:29 PM   #28 (permalink)
Wandering in time...
Ankur Gupta's Avatar
does cleaning reduce the temp by more thn 2 degress??
and installing 2 chasis fans better thn 1 or is 1 sufficient?
and is 40 degress temp ok for my AMD 3000+ 939pin?
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 08-04-2006, 09:31 AM   #29 (permalink)
man...ru crying over 40degrees ????
here iam ... having coolermaster Ultra Vortes running on a server chasis, have 1 front intake fan,i side intake fan, i rear out fan ... and the idle temp is 54!!
((pheeew dropped 6 degrees by adding coolermaster vortex....))
and on load it goes o 67-69max....wheras before on stock cooling it was 78-80 .... !!!
Old 08-04-2006, 04:56 PM   #30 (permalink)
Eazy's Avatar
here iam ... having coolermaster Ultra Vortes running on a server chasis, have 1 front intake fan,i side intake fan, i rear out fan ... and the idle temp is 54!!and on load it goes o 67-69max....wheras before on stock cooling it was 78-80 .... !!!
Here... cry about this.... attached screenie of MotherBoardMonitor readings in my setup ..... these are idlings temps - I dont run Benchies or games so no LOAD temps but on 100% CPU usage temp goes max to 43C. No A/C and room temp is 31C.
My setup P4 2.4C @ 3.0 .... HSF = Zalman 7000CU .... case Antec P160 with 3 x 120mm fans.
Eazy is offline
