Old 01-04-2006, 01:04 AM   #1 (permalink)
Default Stupid IR port.
now, this is my first post after having tried the chip forum (townsquare), which disappointed me. I recently bought an IR port for my 6020, it worked fine for a few days, but then went beserk. Nokia PC Suite doesn't detect my cell through it, my friend's 6601 is detected on his comp using this stupid port. i tried reinstalling it, but to no avail. Please help, I spent 400 bucks on it.
crackalikeit is offline
Old 01-04-2006, 01:29 AM   #2 (permalink)
Didnt you check your cell at your friend's place ???
cyrux is offline
Old 02-04-2006, 12:08 AM   #3 (permalink)
i did!!! the same thing happened, it worked for a few moments and then... well, the port is with my friend now. ?Wait, while installing the drivers, i got a pop-up msg. mentioning some problem about driver signing for windows, altough that had happened at my friend's place too.
