Old 31-03-2006, 08:33 PM   #1 (permalink)
Default AMD 64 3200 + manchester core ?
Can a amd 64 athlon 3200+ have a machester core ?? Check this
Checked it with cpu-z 1.32
cyrux is offline
Old 31-03-2006, 09:50 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
How can u get MAnchester core for 3200, i know they come only in Venice and winchester........and i gueess AMD dual cores have manchester ....can anybody explain me also this one......
wizrulz is offline
Old 31-03-2006, 10:51 PM   #3 (permalink)
Learner
Kniwor's Avatar
No a 3200+ cannot be manchester......
so how do we explain this...
well i have never faced such a situation but as i seems to me this is most prolly a 3800+ manchester..... and for some reasons winXP is only using one core of the 2 and identifying it a single core procy.... now i dont know how valid this explaination is...
other thin is it can be a paint trick...... as simple as that...
but there os no manchester 3200+ single core for sure....
Kniwor is offline
Old 31-03-2006, 11:20 PM   #4 (permalink)
nishant_nms's Avatar
Is it ur PC
nishant_nms is offline
Old 31-03-2006, 11:37 PM   #5 (permalink)
Yes this is my PC. Secondly this is not a dual core system, i didnt pay that much ....lol
I think this is a winchester core. The cpu-z couldnt indentify it , thats what i can conclude. This is the latest version of cpu-z 1.32, which is last updated on 3/3/2006 . I feel this version has a bug. The last version of cpu-z 1.31 couldnt detect what core my cpu had.
cyrux is offline
Old 31-03-2006, 11:48 PM   #6 (permalink)
This should be the case
Old 31-03-2006, 11:52 PM   #7 (permalink)
darklord's Avatar
Well there is a possibility of this being a Manchester Core.Simple reason being it is E4.Normallly Venice are E3 or E6.
There is a very small chance that a particular Manchester Core was so bad that It didnt even pass 3500+ or single core 3800+ usability so instead of scrapping the core,AMD castrated it and sold it off as 3200+
Just my 2 cents.
darklord is offline
Old 01-04-2006, 12:14 AM   #8 (permalink)
Learner
Kniwor's Avatar
Just my 2 cents.
well sorry but this is not possible, a manchester core contains 2 processors and is much different by design...
if one core stops working i dunno how will the processor react but it cannot certainly be made a single core... the Hypertarnsport is shared... so i am sure there is some sharing algorithm..... and it is actually more complicated than that if u see the dual core structure.....
Kniwor is offline
Old 01-04-2006, 04:19 AM   #9 (permalink)
Fine guys ,finally got through . After searching on google for a while i came to a conclusion that and amd athlon 64 S939 3200 + does have a manchestor core with e4 version
Take a look at this site for your convenience. Just scroll down a bit where you will find this package
http://www.msi.com.tw/program/produc...UID=608&kind=1
cyrux is offline
Old 01-04-2006, 05:55 PM   #10 (permalink)
darklord's Avatar
I know Manchester is Dual Core ka core
Well there is a correction,the 2 cores do NOT share the HTT bus.
Check for urself, AMD Dual Core Architecture
Also the memory controller is also only 1 and not an independant for each core.
So if one core stops functioning,disabling it and using the other core is VERY much possible.
Also i may be dumb but not dumb enough to be unable to understand and know the basics.
darklord is offline
Old 01-04-2006, 06:14 PM   #11 (permalink)
Learner
Kniwor's Avatar
Hey darklord It´s My Bad.....
I searched and found that these processors are actually dual core manchesters whose one core has gone bad
so u can compare them to, say, San Diego SH-E4 with half of its Cache L2 disabled like the ADA3500DAA4BN
Here is the processor.....
http://www.amdcompare.com/us-en/desk...=ADA3200DKA4CG
i was really on wrong lines there.....
@cyrux
thanks for pointing that out man......!!!
@darklord
about the bus... they actually do share the Hypertransport bus(please dont call it HTT,u know why) ..... but my conclusion was not quite right.... as i have already stated...
Kniwor is offline
Old 02-04-2006, 07:30 PM   #12 (permalink)
darklord's Avatar
Why shouldnt i call it HTT ? isnt it whats it called?
Oh you want me to call it LDT...fair enough.
darklord is offline
Old 02-04-2006, 08:43 PM   #13 (permalink)
Learner
Kniwor's Avatar
HTT is name for INTEL's hyperthreading..... but AMD uses the full word Hypertransport.... newbies often confuse.....
hey give it some time... Hyperthreading is almost dead.... so when Hyperthreading is gone... we will call it HTT
Kniwor is offline
Old 02-04-2006, 11:05 PM   #14 (permalink)
darklord's Avatar
Well to be precise,
HT - HyperThreading
HTT - Hypertransport
AFAIK no one calls Hyperthreading as HTT.
darklord is offline
Old 02-04-2006, 11:30 PM   #15 (permalink)
Learner
Kniwor's Avatar
They call it
HTT = Hyper Threading Technology= HT Technology
Hypertransport is just Hypertransport.....
Kniwor is offline
Old 02-04-2006, 11:42 PM   #16 (permalink)
darklord's Avatar
if you say so...
darklord is offline
Old 03-04-2006, 12:21 AM   #17 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Can now any body tell which one is better core, venice, windchester or manchester????
wizrulz is offline
Old 03-04-2006, 02:36 AM   #18 (permalink)
venice , if you are going for a single core
cyrux is offline
Old 03-04-2006, 11:14 PM   #19 (permalink)
darklord's Avatar
AMD Athlon 64 939 pin based CPUs have basically 2 versions of Venice core.
E3 and E6.
Getting E6 is recommended for lesser heat output.
darklord is offline
