Old 31-03-2006, 07:43 PM   #1 (permalink)
Default help on upgrade ; what processor to chose ?
hi , i'm planning to upgrade my computer
its current configuration is :
intel pentium 4 2ghz (notOC)
ASUS P4S-333 VM motherboard
512mb ddr333 ram
80gb 7200 rpm hdd
the mobo has an AGP 4x slot and i have ASUS GE-FORCE 4 64MB on it
i want to upgrade it to be able to install 6600gt on it
either somebody suggest a component upgrade or one of the upgrades from below:
1-
AMD Athlon 64 3000+ 939
ASUS A8N-E mobo
1 gb DDR ram 400 mhz
ge force 6600gt 128mb PCIE
2-
INTEL PENTIUM-D 2.66
2mb cache
intel original motherboard (comes along with it as a combo)
1 gb ram DDR2 ram
my use would be basically playing games
and try to keep the price low , but i'm not on a tight budget , just would like to save money .
amritsingh87 is offline
Old 01-04-2006, 09:54 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
AMD for games, look no further.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-04-2006, 10:00 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Amen to that!
kalpik is offline
Old 01-04-2006, 10:19 AM   #4 (permalink)
Professional Layabout.
pickster's Avatar
BTW, isin't this in a wrong section?
pickster is online now
Old 01-04-2006, 10:29 AM   #5 (permalink)
Commander in Chief
Yes, its reported tho... new members hardly care to read rules...
Harsh J
www.harshj.com
Old 01-04-2006, 06:47 PM   #6 (permalink)
AMD
ashnik is offline
Old 01-04-2006, 09:36 PM   #7 (permalink)
ymhatre's Avatar
Offcourse AMD but go for 3200+
cuz buying 3000+ or 3500+ both r useless considering Prices...
Buying 3500+ is having too much prize difference though the performance is little more than 3200+
while buying 3000+ is doing Foolishness
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 02-04-2006, 11:52 AM   #8 (permalink)
nishant_nms's Avatar
AMD man
nishant_nms is offline
Old 02-04-2006, 04:44 PM   #9 (permalink)
Your Maker.
MysticHalo's Avatar
Get 2GB RAM...thats my advice
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 02-04-2006, 05:12 PM   #10 (permalink)
gooby pls
Third Eye's Avatar
AMD FOR PC !
Third Eye is online now
