i am going to buy
1.> Athlon 3200+
2.> Asus a8n-vm csm
i can't go for all the high end cabinet( which seems to be good in every aspect) mentioned in the forum.
so i will buy a cabinet available locally.
I want u ppl to plz suggest me
1) what are the constructional details that i should look for, in a good cabinet?
2) i have heard that the northbridge (particularly in this mobo) heats up considerably (although passively cooled), so plz suggest a solution?
3) Any other advice that u would like to give.
