Old 30-03-2006, 10:09 PM   #1 (permalink)
ymhatre's Avatar
Default TOO HOT NEED COOLING DEVICES
HMMM Summer is getting too hot
I need some cooling devices.....
I hav got budget of Rs 500
I m having Intel P4 2.66 (533)
P5RD1 - VM mobo
300 Watt SMPS
Having VIP G300 Cabinet
This Cabinet has got many options for fitting FAns...
NOw the prblem is tht im having no FANS...
I just wanna know which fan i shld buy...
My budget is till 500....
PLz help me...
Though the temp of Pc is around 39 - 42 degree always...but then too im thinking of overclocking it...
PLEASE SUGGEST FEW COOLERS....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 31-03-2006, 11:14 PM   #2 (permalink)
mayanksharma's Avatar
yeah try one from coolermaster or from Zalman.
Either put on good thermal paste from coolermaster and then try velocity from the same. It works great.
If there is any possibility to change cabinet then choose the one from Antec with supersilent option or caviar from coolermaster.
thats it.
bye.
mayanksharma is offline
Old 01-04-2006, 12:00 AM   #3 (permalink)
thats it.
bye.
Either you didnt read the first post properly or dont know the price of antec cabinets...
He mentioned a budget of 500 . Antec PSUs cabinet start of from 4k(the 4k one has the least pwoer O/P. A 350 W would atleast cost 6k)
cyrux is offline
Old 01-04-2006, 12:08 AM   #4 (permalink)
yogi7272's Avatar
vip g 300 has options for 4 fans .. 2 in front and 2 back all 80 mm .. so get ur self some good 80 mm fans and put 2 of them in front sucking the air inside the cabinet and put other 2 at the back pulling all the heat out of the cabinet .. also make sure the fan on the side panel is blowing the fresh air into the cabinet not outside .. also i think the g 300 has option on the opposite side panel .. i mean panel on the back of the board .. if possible then do put a fan their blowing fresh air on the back of the mobo and see if that helps ..
yogi7272 is offline
Old 01-04-2006, 05:51 PM   #5 (permalink)
ohhhh sorry for that.
i didn't read your budget.
but in my post i have also mentioned the thermal paste from coolermaster.
And with your budget, you can choose from various Coolermaster cooling fans.
Believe me they are just great,and will definitely help you cooling your cabinet.
Old 01-04-2006, 08:38 PM   #6 (permalink)
ymhatre's Avatar
@ yogi7272
Thnx for ur support
But i was knowing tht
My quetion is which fan to go for n how much does it cost....?
@ mayanksharma
R u talking about applying thermal paste to the processor...
IF yess Then i have a question 4 u???
After applyong thermal paste by how much temperature of processor reduces
Also were can i get this paste whts d cost of it...
DusT = ME
ymhatre is offline
Old 01-04-2006, 10:13 PM   #7 (permalink)
Technoholik !!
Tech&ME's Avatar
Originally Posted by ymhatre
@ yogi7272
Thnx for ur support
@ mayanksharma
@ mayanksharma
Are you out of your mind ? What the hell are you suggesting, to apply thermal paste in a Prescott processor ? Where did you learnt that ?
@ymhatre
You can buy extra fan for your cabinet from coolermaster, they will cost you 200 to 400 (depends upon your choice of models).
You also mentioned about overclocking., What are you going to overclock anyways ?
Tech&ME is online now
Old 01-04-2006, 10:25 PM   #8 (permalink)
ymhatre's Avatar
@ tech me
THNX
YES also i had heard tht prescott processor dont need any thermal paste as it is already present...
also as u know im having G300 cabinet... i will definetly go for good fan... no matter 200 or 400
yes i want to overclock my processor.
Im having one Qs
since im having 300 WATT SMPS will
tht be OK for overclocking
DusT = ME
ymhatre is offline
Old 01-04-2006, 11:49 PM   #9 (permalink)
yogi7272's Avatar
listen buddy , ymhatre .. as u have 2.66 with 533 fsb , ur p4 has a lot of headroom for overclocking .. also u seem to have asus board which is the best mobo maker where overclocking is concerned for intel procis ..
now abt the coolermaster fans ... they are costly ..80 mm for 572 rs ..
i do have complete pricelist for coolermaster and antec products .. these are excellent products but are costly .. now u can go for a local brand fan which is available for 35 rs at lamington road .. also antec 80 mm pro fan is available for 291 rs each .. so better get local fans which are cheap
also the thermal paste which comes with intel stock cooler is good but not sufficient especially here in india in summer .. better use all ur funds to buy a nice thermal paste like arctic silver 5 - 650 rs or arctic ceramic -550 rs or cooler master thermal compound -208 rs or cooler master premium thermal compount -676 rs or antec silver compound - 650 rs
out of these i have used the cooler master - 208 rs compound which i found better than what intel provides but not sufficient .. the 676 rs premium i told is nice one .. or u can always go for arctic silver 5 which is the absolute best ..
also for overclocking ur proci .. u need good psu with atleast 400 w ratings .. consider powersafe .. which i found sufficient myself ..
i hve done a bit of oc with it .. with no prob what so ever .. i hve oced a
2.6 c to 3.25 ghz with no probs with this psu .. also since temp is rising these days its always advisable to try these oc missions at some other seasons like monsoon or winter .. or get ur self a good cpu cooler if u want to indulge in serious oc .. also do oc ur chip with bios of ur mobo
and not with asus aibooster .. also cooler master has introduced
BLUE ICE a chipset cooler with single heatpipe and 40 mm fan .. reviews for which are available on the net .. this thing is damn good .. keeps temp on ur northbridge within the limit .. specially good for those sli guys .. price is 576 rs
yogi7272 is offline
Old 02-04-2006, 08:30 AM   #10 (permalink)
ymhatre's Avatar
@yogi 7272
Thnx for the info
dude as i said my budget is 500
wht if i wait for abt a month n collect abt 1500Rs
wht shld i then go for...
450/400 watt PSU or Some Stuff frm Coolermaster
Cuz i cant wait for more than a month for OC..
Please suggest...
DusT = ME
ymhatre is offline
Old 02-04-2006, 02:05 PM   #11 (permalink)
Where does the difference lie between local and reputed fans..... Material of blades ? RPM ? cooling ?
Is it really worth going for the high priced fans..Do we get what we paid for ??
cyrux is offline
Old 02-04-2006, 05:19 PM   #12 (permalink)
ymhatre's Avatar
yogi 7272
me too waiting for ur reply
Does going for branded high priced fans is worth
n can u please tell me the price of BLUEICE frm coolermaster
DusT = ME
ymhatre is offline
Old 02-04-2006, 05:25 PM   #13 (permalink)
I know that prescott comes with the thermal compoundings.
But as the options were asked for cooling, then there is absolutely no problem on applying thermal paste to the processor surface.
It will reduce your overall working temperature by 40-50%. Its true.
You can look out for Arctic Silver or Coolermaster HTK-001 or PTK-002.It will cost you around 350-600/- depending upon its availability.
Thanks.
And @tech&Me, for you:-
May be my friend,for once you are kinda new to cooling or might doesn't know at all about it. Then its ur problem pal!!Go and look out for more cooling techniques available out there in the market or try searchin the same on google! You may find out ur answers there. So, never doubt anyone on the topic,to which you are novice or didn't know anything!!
Old 02-04-2006, 05:44 PM   #14 (permalink)
ymhatre's Avatar
Hey guys
@mayansharma n @ TECH&ME
please guys calm down, no fights.
@ mayansharma
actually i said this bcoz while assembling my first Pc i requested the dealer to apply thermal paste on proci..
but at tht time he said tht this is presscot processor...
u dont have to apply a thermal paste on this one..
he said u will need to apply it after 2 -3 years when the layer of the thermal paste is abt to vanish...
hence it is not advisible to apply thermal paste to a new proci...
n my proci is just 4 weeks old..
I m not trying to get diplomatic, but i had also seen some of guys applying thermal paste to a new proci...
But tht is not advisible...
DusT = ME
ymhatre is offline
Old 02-04-2006, 07:49 PM   #15 (permalink)
darklord's Avatar
Well Intel Provides a thermal Pad as thermal interface between the CPU IHS and the Heatsink.
Applying AS5 helps a lot though.It does not reduce temps but helps in bringing down temps down fast.
For example you are doing encoding and CPU is 100% loaded and temps are around 50c but your idle temps are around 35c then after u stop encoding and CPU usage is again at idle then the time required for bringing the CPU temps to 35C mark are reduced greatly by AS5.
it does not bring down idle and full load temps by a drastic margin.
Also when considering chipset cooling, well it isnt required unless you are doing some extreme stuff.
Asus gives sufficient enough Heatsink on its boards.
If you wanna go extreme,adding a fan over it helps considerably,no need for third party chipset coolers.
Also the recent ATI chipsets run pretty cool compared to the NF4 series.
darklord is offline
Old 02-04-2006, 09:03 PM   #16 (permalink)
Technoholik !!
Tech&ME's Avatar
Thanks.
This is not a fight , I just want to make things clear.
I don't know where did you pick up the idea of applying a thermal compound to a Prescott Processor.
Intel has come up with THERMAL PAD, Which usually comes with the processor fan fixed on to the heatsink.
There is a vast difference between a TERMAL PAD and a Thermal Paste. Both work differently.
Do the following experiment and see for your self.
Put the thermal paste (which we apply on P4 socket 478 processors) and see for yourself what happens. You will get your answer.
Next you were talking about the Artic Silver, let me remind you that not only this compound is costly, it does not make much of a difference to temperature, only say 5 C of temp drop.
Another thing to note about this compound is that , its a permanent compound, you won't be able to separate your Processor with the heatsink untill and unless you apply a huge amount of strength. And if at all you apply such a strength to separate the processor with the heatsink, you may permanently damage the processor since, this processor has a different interface (opposite of what we had with the socket 478).
In my opinion, giving advice to people without warning them of suck situations is not a good advice at all.
And for your info, don't think you are the only one who knows everything about cooling. I am a professional assembler myself and have undergone company training from Intel, Microsoft, and HP.
Old 02-04-2006, 11:34 PM   #17 (permalink)
yogi7272's Avatar
go for local made fans .. i was just giving the info for comparisons .. go get some local 80 mm fans .. and put 2 in front and 2 at back in g300 ..
also the thing abt silver 5 may be true .. it gets stucked to heatsink .. and u need a lot of force ... but it does reduce the temp by 3-10 degress when well settled in .. but all these are net info.. i haven't used it personally..
go get a cpu cooler or chipset cooler of cooler master instead of psu ..
yogi7272 is offline
Old 03-04-2006, 01:35 AM   #18 (permalink)
Thanks.
By no offense at all,
dude let me tell you,i am not a professional assembler like you and even haven't undergone training from the companies, you are telling.
But this is pretty sure that, what we do in front of our eyes and practically observes and analyzes the facts, counts more than your so called "training".
And even if you are true to ur words, then believe me you wouldn't have been here arguing on the topic that you are still novice.
By the way, there is absolutely no problem in appying the paste to the new processor.
You must sometimes try visitin' these links:-
http://www.cluboverclocker.com/revie...tra5/index.htm
hardware.mcse.ms/archive23-2004-10-94595.html
www.buyxg.com/store/item.asp?id=184
http://www.newegg.com/Product/Produc...82E16835100007
http://www.xbitlabs.com/articles/coo...c-cooling.html
I am providing these links,not to prove you wrong,but to make you realize the fact only.Please dont take this otherwise.
And it is true that we can only learn from each other.
By the way if something in my previous posts had hurt your feelings...I apologize for that.
Thank you for your time.
Old 03-04-2006, 11:12 PM   #19 (permalink)
darklord's Avatar
You mean to say that the Heatsink is fixed on the CPU when it is in boxed condition ?? frankly that comment of yours doesnt make any sense to me. :roll:
Really ? i didnt know that,care to explain ??
AS5 never reduces temperatures,it reduces the time required for bringing down temps when CPU is brought back to idle state from 100% load.
Yes you can.I have done that zillions of times,without damaging a single processor.
How could you possibly damage a LGA based CPU physically ???
I fail to understand or imagine that.
Well since when did Multinationals like Intel,HP start giving such horrific training?
Looking at your posts i am pretty sure,you were snoaring away to glory while the so-called training sessions were going on...
That applies to you too buddy.Infact giving wrong advice and putting forward wrong concepts is even more dangerous.
Someone once said,wrong knowledge is dangerous than half knowledge or soemthing like ,i dont remember now...lol
But seriously man,your post made me laugh.Thanks for entertaining me.
darklord is offline
Old 03-04-2006, 11:46 PM   #20 (permalink)
But your post darklord made me laugh harder ...rofl
cyrux is offline
Old 04-04-2006, 03:35 AM   #21 (permalink)
wooow!!!!
dats some war of words going on !!!
in the end iam more confused...
but seriously some points put forward by darklord have been followed by me ...
i have a thermal pad and along with it i have applied thermal paste from coolermaster,and as soon as i finish far-cry or anything heavy,the system takes 2/3 seconds to bring the temp down...and in 10 secs its back to normal...maybe due to thermal paste..
grinning_devil is offline
Old 04-04-2006, 07:42 AM   #22 (permalink)
Eazy's Avatar
When you say "along with it" do you mean that you put paste on top of the pad ? Thats not a good thing to do - all traces of the earlier pad/paste MUST be removed before applying new GOOP. If you want to read how to do it properly read this page...
http://www.arcticsilver.com/arctic_s...structions.htm
Eazy is offline
Old 04-04-2006, 08:20 AM   #23 (permalink)
ohhhho...i know what the instructions say...but for me what works best is this way...be it somewhat irregular but still gives me the desired result
Old 05-04-2006, 01:11 PM   #24 (permalink)
by all respectful means, i think ymhatre, should have finally got his cooling solution by now.
And once and again to all, there is no point of proving wrong somebody.
We all here to learn and share from others.
thats it.
and by the way darklord, i have never seen so many lols,winks and expressions in a post. But that surely made me smile.
Old 05-04-2006, 03:17 PM   #25 (permalink)
If ymhatre got his cooling device he should mention it here and inform about this product , cost so that it can help others.
cyrux is offline
Old 05-04-2006, 07:06 PM   #26 (permalink)
Technoholik !!
Tech&ME's Avatar
Nice to see your comments dude,
It seems to me that you don't even know to read ENGLISH !!!!
Quote
"usually comes with the processor fan fixed on to the heatsink"
Unquote
So you don't even understand the meaning of the above sentense, it clearly says,
That the Prescott Processor Fan comes with the heatsink, and the Thermal Pad it fixed to the heatsink. ..... and I never said that the CPU comes fitted to the heatsink. Hope you now understand.
Secondly, I am astonished to note that you yourself doesnot know the difference between the Thermal PAD and the Thermal Paste and is taking part in discussion on such topics, which you are not aware of.
Frankly speaking, Intel is not FOOL company to make Thermal PAD for its Prescott Processor when the old Thermal Paste would still do the same work. They created Thermal PAD specially for this Processor type.
I again ask you to do the experiment yourself see the difference before you comment on such things.
EXPERIMENT:
Instead of applying Thermal PAD while installing an LGA based Processor, apply the ordinary Thermal Paste which we use for the Socket 478 processor, you will yourself discover the difference.
Below i give you a quote from the website of Aritic Silver itself, see what they themselves say about it.
Hope this opens your EYES forever.
Controlled Triple-Phase Viscosity:
Arctic Silver 5 does not contain any silicone. The suspension fluid is a proprietary mixture of advanced polysynthetic oils that work together to provide three distinctive functional phases. As it comes from the tube, Arctic Silver 5's consistency is engineered for easy application. During the CPU's initial use, the compound thins out to enhance the filling of the microscopic valleys and ensure the best physical contact between the heatsink and the CPU core. Then the compound thickens slightly over the next 50 to 200 hours of use to its final consistency designed for long-term stability.
(This should not be confused with conventional phase change pads that are pre-attached to many heatsinks. Those pads melt each time they get hot then re-solidify when they cool. The viscosity changes that Arctic Silver 5 goes through are much more subtle and ultimately much more effective.)
Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
^ So this is how the CPU can be permanently damaged.
Absolute Stability:
Arctic Silver 5 will not separate, run, migrate, or bleed.
Specifications:
Thermal Conductance:
>350,000W/m2 °C (0.001 inch layer)
Thermal Resistance:
<0.0045°C-in2/Watt (0.001 inch layer)
Average Particle Size:
<0.49 microns <0.000020 inch
Extended Temperature Limits:
Peak: –50°C to >180°C Long-Term: –50°C to 130°C
Performance:
3 to 12 degrees centigrade lower CPU full load core temperatures than standard thermal compounds or thermal pads when measured with a calibrated thermal diode imbedded in the CPU core.
Coverage Area:
Arctic Silver 5 is sold in 3.5 gram and 12 gram tubes. The 3.5 gram tube contains enough compound to cover at least 15 to 25 small CPU cores, or 6 to 10 large CPU cores, or 2 to 5 heat plates. At a layer 0.003" thick, the 3.5 gram tube will cover approximately 16 square inches.
Important Reminder:
Due to the unique shape and sizes of the particles in Arctic Silver 5's conductive matrix, it will take a up to 200 hours and several thermal cycles to achieve maximum particle to particle thermal conduction and for the heatsink to CPU interface to reach maximum conductivity. (This period will be longer in a system without a fan on the heatsink or with a low speed fan on the heatsink.) On systems measuring actual internal core temperatures via the CPU's internal diode, the measured temperature will often drop 2C to 5C over this "break-in" period. This break-in will occur during the normal use of the computer as long as the computer is turned off from time to time and the interface is allowed to cool to room temperature. Once the break-in is complete, the computer can be left on if desired.
^ And you were saying there will be NO drop in temperature, silly you!!!
Even though Arctic Silver thermal compound is specifically engineered for high electrical resistance, you should keep the compound away from processor, memory, and motherboard traces and pins. There is a possibility that dust or metal particles and/or shavings carried by the airflow inside the computer case could contaminate the compound and increase its electrical conductivity.
^ Understood something ? This is how damage could be caused
Thermal pads are made with paraffin wax that melts once it gets hot. When it melts, it will fill in the microscopic valleys in the heatsink with wax
^ This is one of the many differences between a Thermal PAD and Thermal Paste
Hope this helps! If you need for post back.
And good luck.
Oh yes! besides, the training, all companies provides training to there dealers. So, I got the training understood.
Old 05-04-2006, 08:25 PM   #27 (permalink)
guys...guys....guys.....c'mon....STOP fighting!!!!
everyone is correct and true to their respective senses....
lets all agree on one point...
PROCESSOR SHOULD BE RUN WITHOUT HEATSINK AND FAN !!!!!
Old 05-04-2006, 08:36 PM   #28 (permalink)
I dont think there is any fighting over here. No harsh words used no abusive language used This is just a good healthy debate due to contradiction in views or communication. I think such debates shouldnt be discouraged . Its due to such debates the 2 persons involved and many other readers come to know about such new things
But lets keep it cool and no flaming grinning here
cyrux is offline
Old 05-04-2006, 08:42 PM   #29 (permalink)
ymhatre's Avatar
Sorry Guys.. but im confused between wht to go for n wht no to...
I feel tht i shld be diplomatic...
Both of them had justified me by mentioning linkss all stuff.
So please conlcude me a final solution...
I HAVE STARTED FEELING like hanging sword is on my head....
please tell me wht to do....
As i mentioned earlier.. ihav got budget abt 500...
but could make 1500 if i wait for abt a month...
so im confused on wht to go for..
Shld i go for thermal paste... or shld i fix new heatsink(blue Ice) or shld i add abt four fans to this cabinet...
My sole purpose is to overclock my intel 2.66 to say abt 3/3.2 GHz..wiht out much inscrease in temperaure...
current temp of proci is around... 40c...
n always remain around 40 - 39 c
only increase till 45- 47 c while playing games like NFSMW...
so tell me guys now wht to do....
DusT = ME
ymhatre is offline
Old 05-04-2006, 08:45 PM   #30 (permalink)
you think iam the one who is flaming??????
If yes then check your eye-sight,you are not clearly looking at posts...
and as far as coming to the point whether it should be discouraged or not-i never discouraged them,ppl can go on quoting each other as much as possible....but do you by any chance know the real problem or query thread starter posted...he wanted a simple answer...a few cooling solutions under 500 bucks...with so much confusion between views ppl who are new to this are surely going to get lost..
