Old 30-03-2006, 11:15 AM   #1 (permalink)
ninad_mhatre85's Avatar
Default 20k buget for pc
hi
my friend want to buy new pc in 20k
can u suggest me good confi in that buget
he doesnt play games so no need for gra card. he wants DVD writer and atlest 15 " monitor( for basic use)
remaining depends on u.
bye
ninad_mhatre85 is offline
Old 30-03-2006, 11:46 AM   #2 (permalink)
darklord's Avatar
AMD Sempron 2500+ --------------->2,500/-
Asus K8V-MX------------------------->2,800/-
512MB DDR400 Memory------------>1,800/-
80GB HDD---------------------------->2,400/-
16X LG 4167B DVD-RW------------->2,500/-
15" Samsung/LG CRT Monitor------->4,500/-
Full ATX Chassis---------------------->1,000/-
Powersafe 400W PSU----------------->1,200/-
Keyboard+Mouse ---------------------> 450/-
Multimedia Speakers -----------------> 400/-
Total - 19,550/-
There you go buddy.
darklord is offline
Old 30-03-2006, 12:09 PM   #3 (permalink)
Buy a 17" CRT. Its only slightly more expensive and 15" is just pathetic.
drvarunmehta is offline
Old 30-03-2006, 01:34 PM   #4 (permalink)
My friend got a samsung syncmaster (dont rem. the model no) 17" (black) for arount 4.1k
cyrux is offline
Old 30-03-2006, 05:44 PM   #5 (permalink)
i feel u can save some money by going for 256 MB of RAM which should be enough for a low cost machine as application will not be very much demanding...further ATX and PSU rates are 2200 rs. combined which is more in my view....no need to go for a rugged powersupply of 400 W for a low cost machine...best bet is to go for a VIP cabinet with 300-350W of integrated supply for about 1500 rs....money save can be used for 17' monitor...and a better CPU....
Ankit is offline
Old 30-03-2006, 05:54 PM   #6 (permalink)
darklord's Avatar
Well the board i have recommended use onboard grafix and that shares memory from System memory.I think it would be wise to stick with atleast 512MB Ram.
Also Powersafe 400W is a bare minimum these days as the current lot of 300W PSUs is sheer crap.
I dont understand why an important component like PSU is given so less importance ?
darklord is offline
Old 30-03-2006, 09:06 PM   #7 (permalink)
see this config ,its the best hi-fi config
http://www.tech2006.zeeblo.com/Pc20.html
1)Processor : AMD Sempron 2500+ 64Bit Socket 754 CPU - Rs 2500
2)MotherBoard : ASRock K8NF4G-SATA2 Motherboard - Rs 3,400
3)Memory : Hynix 512 MB DDR-400 RAM - Rs 1,900
4)Cabinet : Frontech ATX Cabinet with 400 Watts SMPS - Rs 1,200
5)HardDisk : 80 GB 7200 RPM Seagate Barracuda SATA Hard Disk - Rs 2,600
6)Monitor : ViewSonic E70 17" Monitor - Rs 4,900
7)Combo Drive : Lite-On 52X/32X/52X/16X Combo Drive - Rs 1,800
8)Speakers : Altec Lansing ATP3 2.1 Speakers - Rs 2800
9)Keyboard : Adcom Multimedia Keyboard - Rs 150
10)Mouse : Adcom Optical Mouse - Rs 200
Total - Rs 21450/-
Advantages:
*The system will be able to run The upcoming Windows VISTA Smoothly
*Onboard Nvidia 6100 Graphics
*Onboard Realtek ALC850 8Channel Sound
Rajesh_81 is offline
Old 30-03-2006, 10:49 PM   #8 (permalink)
Too much money wasted on speakers for a 20k PC.
Buy a Creative SBS2.1 370 for about 1300 and spend the rest on a Logitech keyboard and mouse. Don't even think of buying this Adcom rubbish.
Old 30-03-2006, 11:05 PM   #9 (permalink)
ymhatre's Avatar
HEy guys all giving him post of AMD related rigs...
Even there r good rig of celeron n pentium coming around 20000
here it goes
P4 2.66 intel 533 ---4600
Asus P5RD1 _ VM --- 3200
80 GB 7200 RPM Seagate Barracuda SATA Hard Disk - -- 2600
Normal ATX Cabinet with 400 Watts SMPS --- 1000
Liton DVD writer --- 3000
ram 512 (400) --- 1600
optical keyboard mouse --- 450
ViewSonic E70 17" Monitor --- 4900
21350 Rs PC with performance also good onboaard graphics...
can reduce prize if goes for 15 " monitor
I dont think Speakers is mandiatory here.....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 30-03-2006, 11:44 PM   #10 (permalink)
Buy a Creative SBS2.1 370 for about 1300 and spend the rest on a Logitech keyboard and mouse. Don\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\'t even think of buying this Adcom rubbish.
Please be clear
Dont even think of buying SBS and Inspire models from Creative.They are the low quality models offered by creative.
Just increase the bass to above mid level and the sound quality will suckk.
Creative got its name from megaworks THX certified speakers.But they are costly.Those SBS and Inspire models are purely rubbish.They dont even have Treble button.
Same problem with ALtec Lansing.But Altec Lansing speakers sound much better than creative.
If u are listening to a subwoofer sound for the first time then you will like any subwoofer sound be it from any low quality model like SBS,Inspire,AVS200.
If u want the best 2.1 speaker then go for ATP3 only.
Can u tell me advantages of Logitech mouse from Adcom mouse?try both of them then You will know which is better.Adcom is much better than logitech KB and Mouse performance and looks wise.
Old 31-03-2006, 10:10 PM   #11 (permalink)
Ok so ATP3 is better than SBS 2.1, but he didn't say he wants the best 2.1 speakers. He wants speakers that fit in his budget. Spending 2.8k out of a 20k budget on just the speakers is just stupid.
And I won't even bother justifying why Logitech is better than Adcom. It just is.
