Today I was playing NFS most wanted when suddenly i heard some noise from the CPU. I had to forcefully shut down the system. i thought it might be some dust related problems so opened up the cabinet and cleaned up the fan of processor. Then opened the system to find no noise. So i concluded that dust had been the problem. i started playing the game again. Then again i witnessed the same problem. I closed the game and opend a utility "easy tune 5" which is a hardware monitor utility. i saw the CPU temperature was 53 C (since its quite hot these days). The cpu fan was rotating at 5200 rpm which is quite high and was cause of the noise. Usually the fan rotates at 4500 rpm at max.
Then i enabled the S.M.A.R.T. fam from bios and made some changes in utility that the fan would rotate with 100% speed only when the temperature reached only 63 C. At lesser temperature it would rotate at lesser speeds.
Now my concern is that , with an AMD 64 processor is 53-55 C high ? I have witnessed INTEL prescott processors running a 60-70 C quite commonly. So is it really a prob ?
My system config. AMD athlon 64 3200+ , gigabyte k8n51gmf9 mother board (Nvidia 6100, 430/410 MCP)
