Old 29-03-2006, 01:11 AM   #1 (permalink)
Default BAR CODE MACHINE WANTED
Hi i want to bar code machine for my dads shop. I will assemble computer for the shop all by myself. But m unaware about the brand, price, about the bar code machine. I understand that it consists of barcode reader and the software should also be developed for my usage.
Anyway give me all the details u can provide which includes brand, manufacturers website, price, software etc.. what ever u can....
This is urgent as i want this to start working from 1ST APRIL... as it is the begging of new financial year.....
varungupta17 is offline
Old 29-03-2006, 01:43 AM   #2 (permalink)
>:)I-):(|)8-X
Charan's Avatar
AFAIK there are two kinds barcode readers based on the interface type USB and serial (COM). What billing software do you use?? I guess most billing software will have a inbuilt barcode reader software routine.
Here is a search in ebay link
know more about barcodes link
A excel addin link
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is online now
Old 29-03-2006, 12:19 PM   #3 (permalink)
aadipa's Avatar
I have worked/made programs for barcode readers and printers. From what I know, barcode readers are just replacement of keyboard.
Barcode reader just scans barcode and send it as a series of key press (simple text as if typed on keyboard). It just makes out job simpler.
What you need to do it just connect barcode reader to keyboard port/USB port and it is detected as Input device.
In some cases barcode scanner will fail to read the data so you will have to type in that code using keyboard. Your application must have such function. Also you can configure your scanner to send some keys after reading a code. So you can configure it to send code followed by a tab key and you can directly move to next textbox on your application interface.
About specific hardware vendors, I don't have idea about current market, I used to work for HCL BeePOS about 2 years back.
1 aadi + 1 aadi = 1 full
aadipa is offline
