| Forum |
#1 (permalink) |
i have P5RD1-VM board with me it has TV out port please see this HEre theres an tv out option as marked by an arrow... NOw where will i get such kind of cable to connect it to TV... Even bios has some option like Tv out PAl / NTSC... |
#2 (permalink) |
Hey dude u will have to contact ur computer reseller...
Now a days all mobo gives tv out card free with the mobo free... Any way what u can do is go to ur computer reseller and buy a tv out card which will fit behind ur cabinet. It will have either composite or s-video or both cable out. From here u can connect ur tv using appropriate cable and watch tv.... |
#3 (permalink) |
Contact any ASUS dealer if possible auth. one. U will definetly get it there
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#5 (permalink) |
Check it out at http://in.asus.com/
#6 (permalink) |
@ varungupta17
THNX but i was knowing the Site... And its useless i even had call trying ASUS. They keep on Saying Engineers r not available 2day, PLEASE CALL 2MOROW I want exact dealers address n phone no..
!!!From DusT it StartS...... to DusT will EnD!!!! DusT = ME Rate me if was clear to you |
#9 (permalink) |
I have MSI RS 482M4-ILD Mobo with TV out connector. The TV out bracket at the back has RCA composite and S Video connectors. How do I connect to TV and what cable do I require? What is it called in common parlance and where do I buy it ?
#10 (permalink) |
it depends on ur TV model too
If ur having TV tht has Svideo support then just go for Simple Both side S video cable.. Or else go for Svideo to A/V cable... they just cost around 30 - 50 Rs... Just go to ur computer stationary there u could find it...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
