Old 27-03-2006, 08:20 PM   #1 (permalink)
Default Anyone Knows abt this card
XFX GeForce 7300 GS TurboCache 256MB Supporting 512MB TurboCache DDR2 PCI Express DVI VGA TV Out Video Card
and this one
XFX GeForce 6500 256MB DDR2 PCI Express DVI VGA TV Out Video Card
Which one's a better performer?
i read the system reqs for the former and they r mainly requiring 1GB of RAM
the latter's reqs r less
Pentium 4/Celeron, AMD/Athlon
PCI Express 16x Slot
For Full 128/256 support, 512MB system is required
Installtion software requires CD-ROM drive
DVD Playback requires DVD Drive
Windows 2000/XP
the former costs $70 while the latter $60
help me to decide and buy one
A minimum 400 Watt Power Supply
makarand is offline
Old 27-03-2006, 09:10 PM   #2 (permalink)
darklord's Avatar
Geforce 7300GS is a better card,it supports 512MB via TC tech.it has onboard 256 MB buffer but to utilise the full 512MB TC thing,your system needs to have more than 512MB system memory cos the sharing is done thru the system memory.
Also the 6500 is a castrated 6600 no gt,no point going for it.
the 7 Series cards are much improved also.
darklord is offline
Old 27-03-2006, 09:41 PM   #3 (permalink)
With just a $10 difference, it makes no sense to buy the 6500.
drvarunmehta is offline
Old 28-03-2006, 09:38 PM   #4 (permalink)
ymhatre's Avatar
Yeah theres no sense at all in saving (10 * 45 = 450 Rs )
DusT = ME
Rate me if was clear to you
ymhatre is offline
