Old 27-03-2006, 11:54 AM   #1 (permalink)
Default Monitor display is all Pink.
Hello everyone,
I want to pester you guys (again) with another query, hope you will help me out.
The Problem.
When I started my desktop computer today all the windows have a pink background. Before shutting down last night they were white.
The monitor screen flashes a few times converting from a normal white display to and then settles on a not-so-nice Valentine-pink. Both the display are not permanent, it keeps on changing back and forth.
What I have done.
I tried changing the display settings in Control Panel, checked for driver updates, checked for viruses, but the pink hue remains. One of my friends advised me to check if the pins are bent, although I did not do that ,but I did shake the wires. I don't think the pins are bent because I there is no reason for the pins to be bent.
What else can I do?
Thank you.
Neha.N is offline
Old 27-03-2006, 12:32 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
See first if u can get a friends monitor and connect that to CPU and see if its the same problem...if it is then YIPEEE its tiem for new monitor
If no then some thing wrong with ur display card (i guess)..... if u do not have an onboard display card YIPEE again get a new card....and if its onboard then Hurray(this time ) get an new motherboard....
But i advise take an second opinion before buying anything...
wizrulz is offline
Old 27-03-2006, 05:18 PM   #3 (permalink)
check out for the speakers nearby or some equipment radiating magnetic field,most of the monitor are magneticlly shielded but just try it it might work also try the solution suggested by wizrulz, i.e bring a diff monitor and check it if that works fine u just need to repair the cord connecting your monitor to the cpu.
www.guessthelogo.blogspot.com
harshagarwal is offline
Old 27-03-2006, 07:00 PM   #4 (permalink)
Hanging, since 2004..
tarey_g's Avatar
@neha , very simple solution as the problem is very common , Change the monitor cable its faulty , when u move/shake the monitor cable u will notice the color changes back to notmal , the connector pins of the cable are loose , chk they are connected properly or not .
Digit forum without nagging ads and with new features = http://www.thinkdigit.com/forum/showthread.php?p=945285
tarey_g is offline
Old 27-03-2006, 07:33 PM   #5 (permalink)
ASH_DSG
Posts: n/a
HI NEHA,
I Think U have make some changes in ur display properties and u have increase the setting of red blue and green colors segment try to default them it should work. Or uninstall ur graphic driver totally then restart and after restart install the graphic driver. It should work I think. Or which windows ru u using do u install an theme changer software which is not compatible with ur windows and it changes frequently check it and uninstall it. Ok bye.
Old 27-03-2006, 08:15 PM   #6 (permalink)
I am typing this on my laptop as I cant make head or tail in my CRT monitor.
Tarey_g I did try shaking the cable but not too much, but it made no diffrence. I even tried slapping on the side of my monitor still no diffrence. I tried to pull the cable out so that I could get it cheched, but it seems like it is fixed at one end, at the monitor end that is.
Originally Posted by ASH_DSG
HI NEHA,
I use WinXP as my OS.
I have never changed the display settings, nor have I installed any themes.
Is this a minor or a major problem. Is it fixable. If I called up a technition how much will it cost for me to repair my monitor.
Neha.N is offline
Old 27-03-2006, 10:20 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its a hardware problem and the problem resides in ur monitor!
Simply contact a hardware mechanic and ask him to open the monitor cover and to check the cable connector in the monitor. Seems the pins in monitor where the cable is connected, are loose...
http://www.AskVG.com/
Vishal Gupta is offline
Old 27-03-2006, 10:30 PM   #8 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Yeah... It's a HW problem...
Same pinky thing happened to my old CRT few months ago... and it crashed RGB balance in my CRT... and everytime I stsrt it I need to hit it to get the color balance back... it was a moistured & loose AC input port to CRT...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 27-03-2006, 10:41 PM   #9 (permalink)
tarey_g's Avatar
don't do that to ur monitor, it won't make any positive diff
i still recommend that u chk ur monitor cable(not the power cable) . if nothing happens do as vishal suggested.
tarey_g is offline
Old 27-03-2006, 11:36 PM   #10 (permalink)
nishant_nms's Avatar
It the problem is also at the time of POST and in BIOS then it is definetly a H/W prob. If it is only in XP it is a driver problem unistall and reinstall it u are done
nishant_nms is offline
Old 28-03-2006, 06:12 AM   #11 (permalink)
Live The Dream!
agnels's Avatar
Due to heating one of the cable connector has become loose inside the monitor cabinet. It's a cable problem. Take your monitor to the service centre. Do not open the monitor yourself if you are not experienced in repairing monitors.
Very high voltages are inside the monitor 26000 Volts. You touch the CRT even when monitor is OFF and you are dead
agnels is offline
Old 28-03-2006, 07:43 AM   #12 (permalink)
last month i also had the same problem in morning when i start the computer monitor work fine for first 10 minutes and after that background becomes red.
It's not a cable problem.the internal circuit has become dry due to some reason.so contact hardware machenic
in my case machenic charged Rs. 100 only.
indian is offline
Old 28-03-2006, 12:53 PM   #13 (permalink)
Just called up an authorised personel today. He will be here within this week.
I did try again, I meddled with the monitor cable for some time. After that I stopped , I don't want my monitor to be damaged furthermore.
Yeah, even when the computer boots up my screen is pinkish. So it is confirmed it is a H/W issue not a driver problem.
Glad to hear the problem is fixable.
Thanks fellas for your time and all of your suggestions.
Neha.N is offline
Old 28-03-2006, 04:18 PM   #14 (permalink)
tarey_g's Avatar
one more suggestion , pls use black font next time u post ,
aaaaaahhh my eyes
tarey_g is offline
Old 28-03-2006, 11:41 PM   #15 (permalink)
Pink fonts make me feel that my monitor is also getting sick like urs
Old 29-03-2006, 06:03 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
first only i told u its h/w problem and had nothingto do with drivers.....
Did u tried getting ur friends or neighbours monitor adn checked out if that works with ur CPU????
wizrulz is offline
