| Forum |
#1 (permalink) |
now yesterday for the first time it experienced improper shutdown and after that I see theboot up time is much more now what I see is first 2 black&white screen featuring some msi motherboard logo and another screen . then windows xp screen comes and insteade of 2 now 5-6 'fill-up' blue goes from left to right . then for about 2-3 second monitor turns black snd then again XP screen comes last for 3-4 second . then my log-in screen comes . I also did defragment , but it is somewhat slow now . so what I should do ?and why it had happened ? all I can say that after the improper shutdown the boot-up time has incresed 10 seconds . can any techie here enlight me with some knowledge ? |
#2 (permalink) |
Commander in Chief
Try closing some unwanted services apart from startups... I too was experiencing that and I closed loads of unwantedies and now boot time is 6 secs (1 scroll of boot screen) and shut is in 3 secs.
U can read what i wrote about major unwanted services here
Harsh J www.harshj.com |
#4 (permalink) |
Posts: n/a
Have you tried Tweaknow regcleaner(http://www.download.com/TweakNow-Reg...ml?tag=lst-0-1) if not you might want to unclog your registry that might cause the problem you can try defraging your hard drive it has a built in defragmenter go to Start\All programs\accessories\System Tools\Disk Defragmenter or theres a possible malware on your computer.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
