Old 26-03-2006, 01:25 PM   #1 (permalink)
Default downloads!
I hav XP and i want to download something from the internet but a box show tht it is connecting to tht site but download never begins. wat can be the prob! ?
yahfate is offline
Old 26-03-2006, 02:39 PM   #2 (permalink)
What ISP are u using?
I think the best solution is to wait
amitsaudy is offline
Old 26-03-2006, 02:59 PM   #3 (permalink)
nishant_nms's Avatar
Use a download manager. i will recommend u to use Free Download Manager. Search google for the site
nishant_nms is offline
Old 26-03-2006, 08:21 PM   #4 (permalink)
Manchester United
abhijit_reddevil's Avatar
This thread may be in the software troubleshooting section. Anyway, as Nishant suggested, use a download manager like Download Accelerator Plus.
But you say that when you try to download, you get the message that d/l is starting but never starts. So how will you d/l DAP? So I think you can try to get that from a computer magazine CD like Digit's CD/DVD.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
abhijit_reddevil is offline
Old 26-03-2006, 11:19 PM   #5 (permalink)
Sometimes the server may also be down in these cases .
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 28-03-2006, 07:51 PM   #6 (permalink)
hi, i need dvd recorder for my samsung dvd burner model tsh552a.can anybody help me out
maxxx is offline
Old 28-03-2006, 08:15 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
@maxxx - Please start a new query thread for questions not relating to running discussions
Harsh J
www.harshj.com
QwertyManiac is offline
